Privateer error
First post, by priv_pleez
Hi, first of all I appreciate all the help you guys provide. I think that I have DosBox all set up, I run install.exe with ONLY SoundBlaster and I get the following error in the DOSbox window:
" 'Memory: Original Current Used
'NEAR 0 31716 -31716
'FAR 0 378524 -378524
'HIGH 0 0 0
Error #1910
Filename=..\..\DATA\MOUSE\pnt.shp
Length =0
Position= 0
Mode =READ
Program halted by code."
The other DosBox window reads: "Exit to error: Pagefault didn't correct table."
Anyone have any idea what this is and how I can get around it, to reach my ultimate goal of playing privateer??
I attached (I think) a screenshot of the errors. Please help!
Thanks,
Mark
Reply 1 of 11, by samtam90
In Daggerfall, I've solved the problem "Pagefault didn't correct table" simply by re-installing DosBox. Try. 😀
Reply 2 of 11, by kawasaki2008
did you ever manage to work out this problem? im having the same problem.
please help
'HIGH 0 0 0
Error #1910
Length =0
Position= 0
Mode =READ
what can i do?
Reply 3 of 11, by wd
Rank DOSBox Author
DOSBox Author
Install the game correctly.
Reply 4 of 11, by kawasaki2008
installed privateer
copied priv.tre file to C:\priv.tre
edit priv.cfg file to c:\priv.tre
edit Dosbox 0.74 Options. ems=false
run Dosbox 0.74
type
mount c c:\privater
"drive c is mounted as local directory c:\privater\
type c:
Z:\> changes to C:\>
type
Priv
'NEAR 0 31334 -31334
'FAR 0 369516 -369516
'HIGH 0 0 0
Error #1910
Length =0
Position= 0
Mode =READ
JEMM unloaded
Please help me. i have tryed everything i can think of but it keeps coming up with this error #1910
ive been told error #1910 means cant read CD but ive changed the priv.cfg file to the directory of priv.tre
most posts on this error are 3-4 years old now. i hope someone has fixed this problem and can help me
Reply 5 of 11, by kawasaki2008
i followed this websites instructions to the letter
http://www.angelfire.com/yt/privater/winxp.html
this is how i ended up with the #1910 error
any suggestions as to another way to use Dosbox to run Privateer? i have the original Privateer Dos CD-Rom
Reply 6 of 11, by wd
Rank DOSBox Author
DOSBox Author
[merged]
Screw that guide, he doesn't even tell which dosbox version he used. It's a very outdated tutorial.
Check the threads on the guides forum about how to correctly install a game inside dosbox.
Reply 7 of 11, by kawasaki2008
i found the problem
you must have your Priv.tre file in your c:\privater folder
your priv.cfg must look like this "=priv.tre"
same thing for RF if you have it
this is if you are running off your HD *recomend it*
if there is anyone out there still interested in playing Privateer i could make a very easy step by step guild for them?
Reply 8 of 11, by ripa
When I installed Privateer, the priv.cfg was automatically set correctly.
Reply 9 of 11, by kawasaki2008
your priv.cfg should read as followed
=D:\priv.tre
but if your running the game off your Hard Drive you change it too
=priv.tre
D:\ just means CD (or what ever driver letter your CD drive is)
when you take it away the game automatically searchs the Privater file for the priv.tre
Reply 10 of 11, by Gamecollector
Tested with 0.74 and my own Privateer + RF CD.
Installed, configured, started w/o any troubles and .cfg tweak.
Abadonware detected? 😀
Reply 11 of 11, by wd
Rank DOSBox Author
DOSBox Author
He stated that it's for the full-HD transition, which was not originally intended for the game.
