green switch
First post, by j'ordos
I have a question about an old PC I have, on the motherboard is a connector for a green switch and LED. Is this green switch for a turbo button or for putting the PC in sleep mode or something like that?
The motherboard is a DFI 586ITXD, intel 430TX chipset. Here's a link: http://stason.org/TULARC/pc/motherboards/D/DI … ITXD-REV-A.html (mine is rev C1+, but it looks pretty much the same)
Reply 1 of 5, by keropi
I am pretty sure the green switch is for some power saving mode...
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 5, by j'ordos
Quite likely, but here's hoping 😀
Reply 3 of 5, by Tetrium
You can connect the green LED to anything you want. Since I never use hybernate, sleep or stuff like that, I just plug it in another mobo header thingy, if there is one
My retro rigs (old topic)
Report spammers here!
Reply 4 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Yep, a sleep button - back then under DOS when I pressed it the computer would *BEEPBEEPBEEP* and shut down video and harddisk and maybe the CPU fan.
1+1=10
Reply 5 of 5, by j'ordos
Ok too bad it's not a turbo button, thanks for the replies!
