First post, by lucky7456969
As there are still some unfilled gaps in hardware implementation in dosbox,
would disassembling BIOS help dosbox developers to find out these unknowns. Also, would DOS (although illegal) source code help implement certain aspects of dosbox as well?
Thanks
Jack
Reply 1 of 6, by wd
Rank DOSBox Author
DOSBox Author
Which?
Reply 2 of 6, by lucky7456969
Hi wd,
For example,
case 0x0c:
// Video configuration
// TODO: Figure out if there is anything worth implementing here.
pvga1a.PR2 = val;
break;
If I have a paradise BIOS, is it a good idea to fill the gap as well?
Thanks
Jack[/code]
Reply 4 of 6, by wd
Rank DOSBox Author
DOSBox Author
Of course you CAN implement that if you're bored but you're way better off putting some
logging into that function and playing some games, checking if something actually writes
data there.
For svga/vesa you may especially try playing with univbe/sdd loaded, or the respective
vga/svga bios.
Reply 5 of 6, by frobme
Many millions of people own completely legal copies of DOS that can be disassembled during execution (they don't even contain a EULA prohibiting that). So there's no need to contemplate breaking a law here.
Copying DOS source code would be illegal, but DosBox doesn't do that.
-Frob
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
I'd guess they actually have some terms about reverse engineering in there,
but never checked since you only need to "emulate effects".
