First post, by RetroGamer99
Hey everyone. I am new to this forum, but I am fairly good with learning how to install games and use them. So here comes my problem: I am able to play System Shock up to the screen where you go to start the game. But after I click on the Start button, I get the following error message:
Our system has been shocked!! But remember to Salt The Fries
System Shock can no longer run due to a fatal error.
Error code 4007
File error
Error creating initial game - Likely insufficient disk space.
I have read up on a few sites about how to solve this problem. And I have tried using both the Memsize command line to increase the memory size of dos box and I have even tried adding the following command line to the auto-exec part of the dos box editing program:
mount c c:\Games -freesize 999
But none of these solutions seem to work. Any help is appreciated.
By the way, I downloaded this game from abandonia.com
I had also tried to get the system shock portable, but when I tried to use StuffIt to open it, there was nothing to open.
What am I doing wrong? Please help?
Reply 1 of 7, by SKARDAVNELNATE
For start, why are you blue?
Games downloaded from abandonware sites aren't supported on this forum. You'll have to seek help on the site you got it from.
Actually I downloaded it myself and started a new game just fine.
Reply 2 of 7, by RetroGamer99
Okay, well I got One Must Fall: 2097 to work on Dos Box just fine. But what I wanna know now is how do I install System Shock Portable? As far as I know, there is no way to extract the files of System Shock Portable using the StuffIt application. So, is there any other way to install it? Or am I out of luck as far as playing System Shock is concerned?
Reply 4 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I think you should disallow users with less than 100 posts to change font colors. Highly annoying, hard to read and just screams "I'm a newbie, haven't read the readme, nor any guide. Hold my hand and solve my problem!"
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 7, by Gamecollector
-freesize 999 make no difference. Troubles are started with 512+ Mb freesize.
So, try -freesize 500 as example.
Reply 6 of 7, by RetroGamer99
Hmm...I did not think of typing freesize-500. I think I should try it. Thanks I guess for the help. At least to those of you who replied to this topic. 😒
Reply 7 of 7, by eL_PuSHeR
[Thread moved and locked]
We don't support abandonware.
