First post, by Seaside
I have this board and has a 2x4 row PS2 pinout.
I would like some help regarding how to connect the PS2 port in the MOBO.
I tried again some combinations but no luck.
wrote:I have this board and has a 2x4 row PS2 pinout.
How many pins does the header have? 4? 5? 6? 8?
Recently had a similiar problem with my VL/I-486SV2GX4 but figured it out after a while (with a little aid from google) 😀
The pinout goes like this
00
0
0
00
My ps2 header from the bracket has red,yellow,green and blue wire.
wrote:My ps2 header from the bracket has red,yellow,green and blue wire.
No idea which color corresponds with which pin there (mine was black, yellow, red and orange I think) ... try to wire it up corresponding to this mspaint powered drawing. That's the way it's done on my mainboard (which is basically the same as if you directly solder a PS/2 jack onto the mainboard) rather than a slotcover with a PS/2 jack.
I will post some pictures now to help you identifying my MOBO pinout. I really want the PS2 port to work.
I know yellow is the 5V and Red is the ground.
http://im1.shutterfly.com/media/47a1df23b3127 … 3D720/ry%3D480/
Here is your board:
http://stason.org/TULARC/pc/motherboards/A/AB … ium-AB-TX5.html
Found the manual on Abit's FTP site. Here is the pinout
1 Mouse data
2 No connection
3 Ground
4 +5VDC
5 Ground
6 Mouse clock
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
@prophase_j
I have the manual but i don't know where to connect the cables on the MOBO.
00
0
0
00
wrote:@prophase_j […]
@prophase_j
00
0
0
00My ps2 header from the bracket has red,yellow,green and blue wire.
You've gotta find out which color corresponds to which signal (or pin on the PS/2 jack) otherwise all other info in this thread is useless 😉
Considering PS/2 jacks aren't rocket science, it should either be visible by eye or you could "beep through" the lines with a multimeter.
