First post, by yuhong
Have anyone installed Win2000 on a 486? It would be fun to see what modern Windows software would run, and which would crash on an 486.
Reply 1 of 8, by leileilol
/me raises hand
One definite way to crash is to get CPU frequency by the TSC function which a lot of apps do......
DirectX 8 and newer refuses to install on 486 architecture at the installer level.
Steam almost runs. I almost entered the valve hardware survey with it 🙄
Reply 2 of 8, by elianda
Infact alot of newer software simply fails without error message on older systems.
Like Everest don't run on a 386/W95, but it should regarding the official system requirements...
IE6 fails on 386, Firefox also.
Most of the Video stuff requires SSE. There is no check, the exe-files usually just crash.
I would really like to see a error message that states already at installer level that the application is compiled for pentium+ f.e.
Just finding out by try and error is really a pain.
Youtube Channel
Reply 3 of 8, by yuhong
IE6 fails on 386
Not that it matters, as IE6 does not run on Win95 which was the last to support the 386.
Reply 4 of 8, by Old Thrashbarg
Not quite true. Windows 95 was the last version that would officially install on such a machine, but Windows 98 will run on a 386, if you patch the installer to disable the hardware check (or install it from a different machine then swap the hard drive over).
...Not that any sane person would want to actually use Win98 on a 386, but that's another matter entirely. 🤣
Reply 5 of 8, by awergh
This is my best attempt with Windows 7
Cryrix 6x86MX @ 233Mhz
512MB RAM
20GB HDD
It wasn't a permanent arrangement it wasn't the fastest experience and I was pretty lazy in putting 512MB RAM when I could of gone for 384MB easily or maybe less.
I think eventually the CPU usage went down from 100% and sortof just permanently fluctuated to something slightly less then 100% I think.
I almost want to install it again to find out. The board is an AOpen board not sure what else about it without looking.
Reply 6 of 8, by Tetrium
awergh wrote:
-snip-
Well done 🤣!
I remember having seen a vid of 7 (or was it Vista?) installed on a s7 Cyrix and it took forever to reach the desktop!
Reply 7 of 8, by awergh
I don't remember the startup time being a huge amount of time but I don't quite remember.
I'm sure you still could get better though I gather it has to be at least a 686 processor from what I read somewhere or something like that.
Reply 8 of 8, by Mau1wurf1977
512MB RAM
20GB HDD
Cute 😜
