terminator future shock crashing
First post, by sammyjammy
I Need Help!! terminator future shock is crashing when i load my game or start new one. it comes p scramble with orange words. How do i fix this?
please help i called bethesda software and type in the stupid area code but nerver gos through or when dose i get hang up. And the lady at the front office says well that are only area code so no help there.
So im hopeing someone can help me fix my game without starting whole new game.
appreciate it
Reply 3 of 29, by sammyjammy
sound blaster why? and how do i add this to dosbox?
Reply 4 of 29, by SKARDAVNELNATE
sammyjammy wrote:
sound blaster why?
To see if the same settings have an effect on my copy. For example, I used:
Select Digital
Sound Blaster 16 at 220, 1, and 7
Select MIDI
Sound Blaster 16 at 388
Extract tfs_130.zip.
Place TFS130.exe in your SHOCK folder.
Start DOSBox as you would but instead of SHOCK.EXE, run TFS130.exe to install the patch.
Reply 5 of 29, by sammyjammy
ok i look at my setup thnx.
would this erase my game?
Reply 6 of 29, by sammyjammy
ok how do i patch it because i download the game from cd. how do i run tfs 1.30.exe?
also how do i pull up my sound settings?
Reply 7 of 29, by SKARDAVNELNATE
That... doesn't make sense. Do you mean you copied it from the disc without running install?
Okay, I found your other topic where you were installing Future Shock repeatedly. So that can't be right.
But you knew how to phrase it appropriately there?
C:\CD GAMES\SHOCK
C:\GAMES\SHOCK\TFS130
There's a file called HMISET.CFG in your SHOCK folder. You can open it with notepad. This stores the sound settings.
Reply 8 of 29, by sammyjammy
yes.
ok but will it delete my save game? i dont want restart over.
here my set up
[DIGITAL]
DeviceName = Sound Blaster AWE32
DeviceIRQ = 7
DeviceDMA = 1
DevicePort = 0x220
DeviceID = 0xe016
Reply 9 of 29, by SKARDAVNELNATE
sammyjammy wrote:
yes.
Err... Yes to what? I'll assume this is to my first sentence earlier and you copied the files from the disc without running install.
Here's how I install it.
I've imaged the disc and named it Future_Shock.iso
Future_Shock.iso is located in C:\DOS
I also have a folder C:\DOS\GAMES
In the DOSBox settings under [autoexec] I have:
  • MOUNT C C:\DOS\GAMES -t dir -freesize 400
    IMGMOUNT D C:\DOS\Future_Shock.iso -t iso
    D:
    INSTALL
I start DOSBox and choose:
  • Change the insall type
    Full installation (38MB)
    Change install path
    C:\SHOCK
    Select Digital
    Sound Blaster 16 220 1 7
    Select MIDI
    Sound Blaster 16 388
To patch it I place TFS130.exe in C:\DOS\GAMES\SHOCK
and change [autoexec] to:
    C:
    CD SHOCK
    TFS130
To play it [autoexec] reads:
    C:
    CD SHOCK
    SHOCK
Make a backup. Install it properly and patch it. Then copy your saves to the new location. I haven't tested if you need to start over after patching. They might still work.
Reply 10 of 29, by sammyjammy
to your 1st qustion yes i follow the instructions on the cd. and it work
i just mounted everythang. i have to put the cd in everytime i start the game but that ok.
I dont know how make them iso i tried.
wow seems like lot work 🤣.
Reply 11 of 29, by SKARDAVNELNATE
MagicISO, it isn't necessary for running games but I prefer using images. Do you have Future Shock installed and working now?
Reply 12 of 29, by sammyjammy
ok i reinstall with the patch do i need to enter the cd? and do i got kep reinstalling evrytime i open dosbox?
Reply 13 of 29, by sammyjammy
Ok it says (congratulations you have successfully upgraded your copy of TFS.
Should you decide to re-install the game from the cd, you will also need to re apply
the patch)
than below that it says
C:\GAMES\SHOCK i type SHOCK to start the game and it still crash.
Reply 14 of 29, by sammyjammy
do i need to re install terminator but with the patch?
Reply 15 of 29, by swaaye
I played a lot of Skynet and Future Shock on DOSBOX 0.73 but it crashed very often. Bethesda's games back then tended to be extremely bug ridden. The patches may make them a little better but I couldn't tell.
I did use ISOs of them.
Reply 16 of 29, by sammyjammy
i cant tell ethier still crashes when i load my game.
How do i install the game with the patch?
Reply 17 of 29, by Freddo
Odd, I don't recall having any crashes in Future Shock when playing it in DOSBox. But then again, I only played the first couple of levels.
Reply 18 of 29, by SKARDAVNELNATE
I gave detailed instructions above. I give up. 😒
Reply 19 of 29, by sammyjammy
ok i read it above. so looks like i did everything right. i re install the game than add the patch than play the game but still crash.
the game was working great till this level
