[pics]Dosbox Hercules mode VS real hercules
Reply 21 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Same as other shot, only with output=opengl. See any difference? There actually is a little bit, if you do a "difference" of the two images in Paint Shop, you'll see small differences in the blending.
If you don't see the vertical blending of pixels going on in these shots, you need to look closer, or blow them up with a viewer.
    9.5 KiB
Reply 22 of 37, by Mau1wurf1977
Can't see a difference in your shots at all...
You didn't go fullscreen yet, did you?
Here two fullscreen pics:
Save them to the desktop, open it as fullscreen and use the arrow keys to toggle between them. The difference should be very visible.
I can't take a screenshot in ddraw as fraps doesn't work with this, but it looks identical to openglnb.
Reply 24 of 37, by Mau1wurf1977
Well bilinear filtering manifests itself in a blurry image. You can call it whatever you like.
Take a look at the screenshots above and if what you see is "pixel blending" in your eyes, then we are talking about the same thing.
Please go fullscreen and you will see that ddraw is clear, whereas opengl is still blurry...
Maybe the difference is that I use fullscreen exclusivity whereas you are using window mode and there could be differences.
But if you go fullscreen I guarantee you that ddraw, openglnb and overlay are clear and opengl is the only one that is blurry.
Reply 26 of 37, by Mau1wurf1977
My screen shots contradict what you said.
So let's investigate the issue further and find out why this is the case...
Can you see the differences in the above screen shots (The ones showing the island). One is clean and the other one is blurry. Is this this the "pixel blending" you are talking about?
My YouTube channel
Reply 28 of 37, by Mau1wurf1977
ripsaw8080 wrote:
How do they contradict what I said?
get some blending of pixels unless you use output=openglnb
Firstly it's "no bilinear" and not "no blending".
My screenshot with output=ddraw shows the difference to opengl. Something that contradicts with your screenshots.
Now this isn't about right or wrong. In my screenshots there is a difference, in yours there isn't.
So let's work together and investigate why this is the case
And your screenshots are poor examples. Look at clean text on a plain background like the menu in my shots, the blending is very easy to see
Oh come one don't be like that. They are fine and show the difference.
Did you see a difference or not?
Also you didn't provide a openglnb image yet. Maybe this will help us move the discussion forward.
Reply 29 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
If you're using aspect correction (aspect=true), you will get some blending of pixels unless you use output=openglnb ("nb"=no blending), and that is regardless of what scaler you use.
I've repeated my statment that you said was not correct, because you seem to have forgotten. Your opengl shot shows blending of pixels just as mine do, although it's much easier to see in mine. So, you've supported my statement, not contradicted it.
Reply 30 of 37, by Mau1wurf1977
Ok I'm getting somewhere now...
There is a difference depending on if you are in window mode or in fullscreen mode.
I did 3 screenshots in window mode and they confirm your findings. The first two are blurry, the final one (openglnb) are clear.
Overlay:
Ddraw:
Opengl:
Openglnb:
Now I need to find a method to do a fullscreen screenshot in ddraw mode!
Have you got any ideas?
Because when I'm in ddraw mode and I go fullscreen (ALT+ENTER), the image suddenly becomes clear, just like with openglnb.
Whereas if you are in opengl mode, the image stays blurry when you go into fullscreen mode.
Or just try to replicate this yourself. Just toggle between window and fullscreen mode in ddraw and opengl mode and you should also notice that opengl stays blurry, but ddraw becomes clear when in fullscreen mode.
Reply 31 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Maybe my use of the word "blending" is confusing to someone that isn't me.
With openglnb and aspect correction, you will get perfectly "blocky" pixels with clean, distinct edges; but they are usually of irregular size (a kind of distortion in its own right).
With ddraw, overlay, and opengl, you will get "bilinear filtered" edges, what I call "blending" between neighbor pixels. Blowing the images up in fullscreen just makes it less obvious because the edges of the pixel blocks are relatively smaller.
There is one way you can get aspect correction and perfectly blocky pixels of consistent shape, but official DOSBox does not support it. Namely, this is the ability to do scaling of any integral in both height and width. Take for example the common 320x200 screen. The correct aspect is 1.2, or pixels that are 20% taller than they are wide. If you scale 320 by a factor of 5, and 200 by a factor of 6, you get 1600x1200. With this kind of scaling you'd have perfectly blocky pixels of regular size and shape with correct aspect.
Reply 32 of 37, by Mau1wurf1977
PrtScrn worked for ddraw mode and for opengl I used fraps.
Fullscreen with ddraw:
Fullscreen with opengl:
So there we go, different outcomes depending on window or fullscreen mode.
Let's summarize it:
Windows mode:
Overlay: Clear (so it appears that openglnb isn't the only mode that doesn't blend, even when only considering window mode 😉 )
Ddraw: Blurry
Opengl: Blurry
Openglnb: Clear
Fullscreen mode:
Overlay: Clear
Ddraw: Clear
Opengl: Blurry
Openglnb: Clear
So in essence, we where both right, however we where unaware that the behaviour is somewhat different depending on if you are in window or fullscreen mode.
However openglnb seems to be the better choice, as it gives you a clear image in both modes!
Well that was a productive session, I learned something new, hope you feel similar...
No, please read my post carefully. The images aren't "blown up". They are in fullscreen mode (Hit ALT+ENTER).
Reply 33 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Fullscreen mode does blow them up, though. How else do you think a 320x200 image scaled to 640x400 with a normal2x scaler becomes as large as your display?
Here is a part of your ddraw screenshot blown up in Paint Shop to 16x. You can clearly see that the pixel blocks are of irregular height. If you really are using ddraw, then your ddraw behaves like openglnb at higher resolutions. Because when I use ddraw at fullscreen, I still get filtered edges; but the edges are so small that it's harder to notice the filtering.
    1.07 KiB
Reply 34 of 37, by Mau1wurf1977
Yea that shot was with ddraw.
There might be other factors we arent aware off. I'm using ATI onboard graphics and W7, so there might be differences depending on what hardware and software one uses.
My YouTube channel
Reply 35 of 37, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I know there are distinct differences due to graphics drivers, that is nothing new. First time I've heard of a case where ddraw behaves like openglnb in fullscreen, though. Maybe we can conduct a poll to see which is the more common behavior (blocky or filtered in fullscreen ) amongst other users of DOSBox. 😉
Reply 36 of 37, by gulikoza
aspect=true uses hardware scaling. That can be blurry with outputs which have bilinear scaling by default (ddraw, overlay, opengl (without nb). The same with fullscreen mode, but that depends on the fullresolution as well. If set to original, there will be no scaling except by the LCD.
Direct3D can do integral scaling 😀
http://www.si-gamer.net/gulikoza
Reply 37 of 37, by Mau1wurf1977
Yea it's quite interesting...
I will just settle for openglnb and recommend it from now on.
It's result seems to be consistent and it doesn't throw Aero when you toggle between window and full screen which is nice...
My YouTube channel
