First post, by garrynichol
I swtiched from auto cycles to 12000 cycles after many trials. When on auto Autocad 10 dos would do some erratic things when plotting (printing).
I tried lowering the cycles with no solution. Then when I increased the cycles considerably the probelm disappeared.
Seems strange. I guess like a plane in flight you may not want to slow down too much or stall and crash or speed up too much and break apart and crash. Faster than 120000 cycles crashes my airplane. ouch.
Anyway I was wondering if there is some sort of cpu comparison for 120000 cycles. Foe instance would it be similar to a pentium V?
I ran it with a print sequence at the same time as on xp intel core 2 duo cpu and an amd k7 cpu computer and they completed the task in almost exactly the same time. Would this be a fair comparison?
120000 cycles = amd k7 athlon?
