First post, by Nomeru
text
text
Sprry to be rude but we don't give support for "abandonware" games because these are basically pirated games.
Is otl-spdr an archive?
Yep. otl's a group
Debian's fucked
text
Copy the command.com to the folder you mount as c. Of course the problem could very well be that it is a downloaded game. No one knows what stuff pirates messed up.
Also try to add -t flOppy to your mount a. Make sure you mount the fOlder with the installer as a and not the folder containing this folder.
command.com is located on Z:\
is that in your path ?
maybe copy the file as Dominus suggested to C and A if the game doesn't use the normal ways of accessing it.
Water flows down the stream
It looks like install.exe call command.com -c from within. And COMSPEC variable don't used.
The solution is - copy command.com to the root of your virtual c: drive.
wrote:I just dont have a floppy drive.
No problem, use disk imaging software on a computer with a floppy drive. Also, USB floppy drives can work
Debian's fucked
