First post, by gammaburst
I'd like to run three command-line apps in a Windows pipeline:
A | B | C
A and C are 64-bit Windows console apps. B is a 16-bit DOS utility. Windows by itself can't do it. I can't simply break up the pipeline and use temp files because it's processing continuous real-time data.
Can DOSBox somehow provide a wrapper around B, passing stdin-stdout-environment-parameters to the 16-bit app? I think the answer is "no". Is there another virtual machine that can do it?
Reply 2 of 2, by gammaburst
Wow, that runs most of my old utilities splendidly. Thank you!
I discovered that a couple of my old command-line utilities use a Phar Lap DOS extender and 386 code, which are beyond MS-DOS Player's capability. Have you seen a command-line-interface VM that can handle it?
