First post, by j'ordos
Hi all, not sure if this is the right forum, but it IS an old PC.
I just got a cheap TV tuner card from someone, which I wanted to try on my p200MMX PC (the only one I have available ATM). After inserting the card and starting the PC however I only got a blank screen. The PC started (HD & fan activity) and the monitor got signal, but no image appeared and I think there also was no POST beep.
So I started pulling out PCI cards (a network and sound card) and putting the TV card on a different slot (the only one available was a shared PCI/ISA slot which I figured might cause problems) but the only thing that happened was that sometimes the monitor wouldn't get signal at all.
My main GFX card is a Ati 3D Rage II, also a PCI card. Maybe the Bios gets confused and insists on using the TV card as video output? There's no AGP or VLB slot on my motherboard (a DFI 586ITXD revB, intel 430TX chipset). The TV card has CTX918 V2 written on it, using a Phillips 7134 chipset and has a an integrated modem.
Anyone an idea? Also, would the PC even be able to handle TV input? (p200 MMX with 256MB ram)
