Reply 20 of 24, by Jorpho
- l33t++
wrote:wrote:Is a retail version of Win 98SE superior to getting an OEM version or vice versa?
The OEM version is superior, because it's bootable. The retail is not bootable.
But then how did you install it?
wrote:No, technically since DOS 6.22 has a program that's almost completely useless which DOS 6.2 doesn't, even the fact that 6.22 has […]
wrote:wrote:as for DOS... DOS 6.22 is better than DOS 6.2... only real difference is drivespace compression.... in case you ever need it 😉
Didn't you just contradict yourself there?
No, technically since DOS 6.22 has a program that's almost completely useless which DOS 6.2 doesn't, even the fact that 6.22 has a program that is of minuscule importance, DOS 6.22 is, in fact better.
Pure logic, dear Watson ;DAm I right, or am I right 😁
I see what you did there.
However... DOS 6.2 comes with Doublespace compression. DOS 6.21 was the version without any drive compression at all.
