Old Thrashbarg wrote:Well, better not use 98. Super pi should be of version 1.5XS and it's mandatory. 1.5XS won't run on 98. The same for wPrime 1.55.
I wonder if perhaps 98SE with KernelEx would work... it doesn't magically fix all compatibility issues, but it does allow a good number of 2k/XP-only programs to run.
That's a bright idea, I never thought of that!
Anyway, I'd already noticed the newest SuperPi wouldn't work on 9x (thus my search for a modded version of SuperPi that worked in 9x and supported fractions of a second, but it won't validate).
elianda wrote:Well, this depends what you want to do with the retro hardware.
For some people it is a cheap opportunity to do some retro overc […]
For some people it is a cheap opportunity to do some retro overclocking.
Though if you are more into archiving/preserving stuff overclocking is a no-go.
There is hardware that is not replaceable at all. Taking the chance of setting specs way beyond limits and risk burning it would be a loss.
Also who would be interested anyway if there is no second system existent for comparison anymore?
Only someone who really doesn't care about old hardware. I'm kinda in the middle, leaning more towards the preservationist side 😉
I wouldn't mind overclocking if the parts I use are parts I have multiple spares of and look fairly used anyway (I won't try overclocking using a CPU for instance that doesn't even have a scratch).
I'd NEVER try overclocking on my Cyrix 5x86-133, it's irreplaceable to me, but I wouldn't mind overclocking the AMD variant too much, provided I don't burn up a motherboard.
Also I won't typically try overclocking parts that for me, have no reason to be overclocked (like a Coppermine 750, why overclock that if you can get a Coppermine 1000 for peanuts?), but to me, overclocking partly fills in the desire for knowledge on behalf of the "what if?" question!
What IF AMD had released a AMD 5x86-200?
What IF Intel had released a Pentium MMX Tillamook 400Mhz?
What IF there was an official Deschutes 366?
This is a small part of what interests me 😀
