First post, by demonmov
- Newbie
Can somebody help me please. I mounted the .IMG file using this in the DOSBox, install it without problem. When i run the game, I get an error:
CD -> AUDIO TRACK NOT FOUND
LOCATION 1
And there is no cue file.
LOCATION 1
Well, create a proper image from your original CD then.
You should try re-imaging your disc. I'd suggest going with the bin/cue format, as it works quite well for titles with CD-audio tracks (such as WarCraft II). 😀
For CloneCd images you MUST mount the .ccd file.
Mount .ccd in the virtual drive (DT or A52/120), declare this drive as cd within DosBox (mount d x:\ -t cdrom, where x - your virtual cd letter), then play.
Gj, Gamecollector was right, now all OK. Thanks all for help.
