GCC 4.6.0
First post, by ykhwong
Recently new version of GCC was officialy released. (Mar. 25. 2011)
http://gcc.gnu.org/gcc-4.6/changes.html
A new optimization flag -Ofast was introduced, and there are some improvements according to the changelog.
Anybody tried it for building DOSBox? Will be there a performance merit?
Reply 1 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
Haven't tried it yet. Sounds interesting!
Water flows down the stream
Reply 2 of 11, by Harekiet
Rank DOSBox Author
DOSBox Author
oh that -Ofast is bound to make everything at least 50% faster!
Reply 3 of 11, by leileilol
does it do it for dos/djgpp too!?! I hope!!!!!
Reply 4 of 11, by Harekiet
Rank DOSBox Author
DOSBox Author
No you'll just have to go for that assembly
Reply 5 of 11, by wd
Rank DOSBox Author
DOSBox Author
-Ohisthatfast is new as well
Reply 7 of 11, by ykhwong
I've just compiled GCC myself in MinGW/MSYS.
GCC 4.6 does not seem to be familiar with the DOSBox SVN source.
make[4]: Entering directory `/c/dosbox_temp/src/cpu'
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../include -I/usr/local/include/SDL -D_GNU
_SOURCE=1 -Dmain=SDL_main -g -O2 -MT callback.o -MD -MP -MF .deps/callback.Tpo
-c -o callback.o callback.cpp
mv -f .deps/callback.Tpo .deps/callback.Po
_SOURCE=1 -Dmain=SDL_main -g -O2 -MT cpu.o -MD -MP -MF .deps/cpu.Tpo -c -o cpu
.o cpu.cpp
In file included from ../../include/programs.h:28:0,
from cpu.cpp:29:
../../include/dos_inc.h: In member function 'void DOS_MCB::SetFileName(const cha
r*)':
../../include/dos_inc.h:544:78: error: expected primary-expression before ',' to
ken
../../include/dos_inc.h:544:79: error: 'filename' was not declared in this scope
../../include/dos_inc.h:544:87: error: 'offsetof' was not declared in this scope
../../include/dos_inc.h: In member function 'void DOS_MCB::GetFileName(char*)':
../../include/dos_inc.h:545:71: error: expected primary-expression before ',' to
ken
../../include/dos_inc.h:545:72: error: 'filename' was not declared in this scope
../../include/dos_inc.h:545:80: error: 'offsetof' was not declared in this scope
cpu.cpp: In member function 'void TaskStateSegment::Get_SSx_ESPx(Bitu, Bitu&, Bi
tu&)':
cpu.cpp:294:37: error: expected primary-expression before ',' token
cpu.cpp:294:38: error: 'esp0' was not declared in this scope
cpu.cpp:294:42: error: 'offsetof' was not declared in this scope
cpu.cpp:298:37: error: expected primary-expression before ',' token
cpu.cpp:298:38: error: 'sp0' was not declared in this scope
cpu.cpp:298:41: error: 'offsetof' was not declared in this scope
cpu.cpp: In function 'bool CPU_SwitchTask(Bitu, TSwitchType, Bitu)':
cpu.cpp:362:49: error: expected primary-expression before ',' token
cpu.cpp:362:50: error: 'cr3' was not declared in this scope
cpu.cpp:362:53: error: 'offsetof' was not declared in this scope
cpu.cpp:363:49: error: expected primary-expression before ',' token
cpu.cpp:363:50: error: 'eip' was not declared in this scope
cpu.cpp:364:52: error: expected primary-expression before ',' token
cpu.cpp:364:53: error: 'eflags' was not declared in this scope
cpu.cpp:365:49: error: expected primary-expression before ',' token
cpu.cpp:365:50: error: 'eax' was not declared in this scope
cpu.cpp:366:49: error: expected primary-expression before ',' token
cpu.cpp:366:50: error: 'ecx' was not declared in this scope
cpu.cpp:367:49: error: expected primary-expression before ',' token
cpu.cpp:367:50: error: 'edx' was not declared in this scope
cpu.cpp:368:49: error: expected primary-expression before ',' token
cpu.cpp:368:50: error: 'ebx' was not declared in this scope
cpu.cpp:369:49: error: expected primary-expression before ',' token
cpu.cpp:369:50: error: 'esp' was not declared in this scope
cpu.cpp:370:49: error: expected primary-expression before ',' token
cpu.cpp:370:50: error: 'ebp' was not declared in this scope
cpu.cpp:371:49: error: expected primary-expression before ',' token
cpu.cpp:371:50: error: 'edi' was not declared in this scope
cpu.cpp:372:49: error: expected primary-expression before ',' token
cpu.cpp:372:50: error: 'esi' was not declared in this scope
cpu.cpp:374:48: error: expected primary-expression before ',' token
cpu.cpp:375:48: error: expected primary-expression before ',' token
cpu.cpp:376:48: error: expected primary-expression before ',' token
Show last 50 lines
cpu.cpp:377:48: error: expected primary-expression before ',' token
cpu.cpp:378:48: error: expected primary-expression before ',' token
cpu.cpp:379:48: error: expected primary-expression before ',' token
cpu.cpp:380:49: error: expected primary-expression before ',' token
cpu.cpp:380:50: error: 'ldt' was not declared in this scope
cpu.cpp:403:42: error: expected primary-expression before ',' token
cpu.cpp:403:43: error: 'eflags' was not declared in this scope
cpu.cpp:403:49: error: 'offsetof' was not declared in this scope
cpu.cpp:404:42: error: expected primary-expression before ',' token
cpu.cpp:404:43: error: 'eip' was not declared in this scope
cpu.cpp:406:42: error: expected primary-expression before ',' token
cpu.cpp:406:43: error: 'eax' was not declared in this scope
cpu.cpp:407:42: error: expected primary-expression before ',' token
cpu.cpp:407:43: error: 'ecx' was not declared in this scope
cpu.cpp:408:42: error: expected primary-expression before ',' token
cpu.cpp:408:43: error: 'edx' was not declared in this scope
cpu.cpp:409:42: error: expected primary-expression before ',' token
cpu.cpp:409:43: error: 'ebx' was not declared in this scope
cpu.cpp:410:42: error: expected primary-expression before ',' token
cpu.cpp:410:43: error: 'esp' was not declared in this scope
cpu.cpp:411:42: error: expected primary-expression before ',' token
cpu.cpp:411:43: error: 'ebp' was not declared in this scope
cpu.cpp:412:42: error: expected primary-expression before ',' token
cpu.cpp:412:43: error: 'esi' was not declared in this scope
cpu.cpp:413:42: error: expected primary-expression before ',' token
cpu.cpp:413:43: error: 'edi' was not declared in this scope
cpu.cpp:415:42: error: expected primary-expression before ',' token
cpu.cpp:416:42: error: expected primary-expression before ',' token
cpu.cpp:417:42: error: expected primary-expression before ',' token
cpu.cpp:418:42: error: expected primary-expression before ',' token
cpu.cpp:419:42: error: expected primary-expression before ',' token
cpu.cpp:420:42: error: expected primary-expression before ',' token
cpu.cpp:428:43: error: expected primary-expression before ',' token
cpu.cpp:428:44: error: 'back' was not declared in this scope
cpu.cpp:428:48: error: 'offsetof' was not declared in this scope
cpu.cpp:430:43: error: expected primary-expression before ',' token
cpu.cpp:430:44: error: 'back' was not declared in this scope
cpu.cpp:430:48: error: 'offsetof' was not declared in this scope
make[4]: *** [cpu.o] Error 1
make[4]: Leaving directory `/c/dosbox_temp/src/cpu'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/c/dosbox_temp/src/cpu'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/c/dosbox_temp/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/c/dosbox_temp'
make: *** [all] Error 2
태웅이@TEDYOO-PC /c/dosbox_temp
However, building SDL library was successful.
Reply 9 of 11, by ykhwong
gulikoza wrote:
Include stddef.h?
Yes, it allows to compile. I added #include stddef.h to dos_inc.h.
Thanks. 😀
Reply 10 of 11, by emendelson
-Ofast isn't nearly as fast as the -Oinstantaneous option reportedly included in 4.7.
Reply 11 of 11, by batracio
-Oludicrousspeed optimization flag is so fast it can execute an infinite loop in a finite time.
