Batch file help.
First post, by dosquest
Okay, I have a file needs user input (1 through 5) how do I restrict the user input. Say if someone typed "r" or another character other than 1 through 5 how would I block that input because when I input an unexpected character is crashes the program instead of ingoing it.
Reply 2 of 4, by Tetrium
I'm not exactly a DOS or batch guru, but I have used simple batch files extensively in the past
Can't you make a statement along the lines of
if 1 goto <your batch continues>
if 2 goto <your batch continues>
if 3 goto <your batch continues>
if 4 goto <your batch continues>
if 5 goto <your batch continues>
goto end
so that if the user input is incorrect, it simply terminates?
My retro rigs (old topic)
Report spammers here!
Reply 3 of 4, by rfnagel
As QBix suggested, using "CHOICE.COM":
@ECHO OFF
:Top
CLS
@ECHO Your Main Menu
@ECHO --------------
@ECHO Option [1]
@ECHO Option [2]
@ECHO Option [3]
@ECHO Option [4]
@ECHO Option [5]
@ECHO.
@ECHO [Q]uit
@ECHO.
CHOICE /C:12345Q
IF ERRORLEVEL 6 GOTO Quit
IF ERRORLEVEL 5 GOTO Option5
IF ERRORLEVEL 4 GOTO Option4
IF ERRORLEVEL 3 GOTO Option3
IF ERRORLEVEL 2 GOTO Option2
IF ERRORLEVEL 1 GOTO Option1
:Option1
CLS
@ECHO This is Option 1!
@ECHO Press any key to return to the main menu...
PAUSE>NUL
GOTO Top
:Option2
CLS
@ECHO This is Option 2!
PAUSE>NUL
GOTO Top
:Option3
CLS
@ECHO This is Option 3!
PAUSE>NUL
GOTO Top
:Option4
CLS
@ECHO This is Option 4!
PAUSE>NUL
GOTO Top
:Option5
CLS
@ECHO This is Option 5!
PAUSE>NUL
GOTO Top
:Quit
CLS
@ECHO Hasta la vista, Baby!
…Show last 3 lines
@ECHO Press any key to exit...
PAUSE>NUL
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 4 of 4, by dosquest
Thanks.
