Geting all Ultima Games working
First post, by JohnReaper21
I recently got the UC disc from a friend as a gift, All it is is the disk so i don't have the manuels. But thats not the point.
I can get ultima one working by simple drag and drop, but every ultima game after that is a bit werid.
U2 and 3 are fast, and no sound. music if there is any
u4 no music if there is any
u5 won't work at all
u6 works fine from what I played sound nad all
U7
and u8 No sound no talking
I can't Install it from the disk because it stops after Microsoft ActiveMovies sincei already have it or os it says any help?
Reply 2 of 23, by JohnReaper21
DosBox, I'm on Vista,
U7 will not boot up, sometihng about a progresser
Reply 3 of 23, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
best you follow the 60 seconds guide 60 seconds guide to getting your game to run in DOSBox
The games can be copied from the Ultima Collection (if you have that). U7 needs ems set to false in dosbox.conf. All Ultima games work fine in Dosbox (except u9 of course). Alos read the dosbox readme for what to do when a game is too fast.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 23, by JohnReaper21
What about music, And sound Can you tell me what games have and don't have it.
Reply 6 of 23, by JohnReaper21
How do I do that, I coppyed the ENTIRE cd to my Computer, now what do I do? I been using drag and drop and that seems to be working
Reply 7 of 23, by JohnReaper21
To limited success.
Reply 9 of 23, by JohnReaper21
It would help If i UNDERSTOOD the instructions...
Reply 11 of 23, by JohnReaper21
I got the Cd mounted but it doesnt have an INSTALL in the cd, and some of the ULTIMA games don't come with it
I can't INSTALL the games I am looking at a list of things with DIR
Reply 12 of 23, by JohnReaper21
how do I open a folder in the CD once I'm in D?
Reply 13 of 23, by retro games 100
cd folderName
where "folderName" is a sub folder on the CD-ROM. "cd" stands for change directory
Reply 14 of 23, by Dominus
DOSBox Moderator
ok, don't follow that part of the guide. copy the games to your hd, mount he top folder (c:\dosgames for example) then cd zto the game and there start setup or install.
Reply 15 of 23, by JohnReaper21
How do I go up one Directory? Ultima1 doesn't have an install file.
Reply 16 of 23, by retro games 100
Hehe, I think you need to read some kind of "DOS quick start guide".
cd ..
That goes up one level.
Reply 17 of 23, by JohnReaper21
Hey retro game do you know what Ultima's have music?
Reply 18 of 23, by retro games 100
Just as an idea - you could click here to go to the mobygames ultima series page, and then click on the DOS game titles that you have, and then click on the "tech specs" link on the left hand side. It should list what sound cards are supported. If it lists something like Roland LAPC-i or MT-32, etc then the game will have music.
If it says PC Speaker, then it's unlikely it will have music - if it does, it will suck! Eg, I looked up Ultima 3, 4 and 5, and they all list PC Speaker. So, probably no music. I also looked up U6, and it listed music sound card hardware. Yes, I remember, I tested this game's music on a GameBlaster - sounded quite good! 😀
Edit: PC Speaker music sounds like beeps. Primitive, but it is music. So, I was incorrect above when I said that if the game only supports PC Speaker, the game won't have music.
Reply 19 of 23, by JohnReaper21
for some reason my sound is normal a 3000 Cycles, but my movements are blurred, any idea how to fix?
