First post, by shotzo
Every effort to get it running has been an exercise in futility. I tried installing it in DOSBox, but the game claimed that it couldn't recognize the CD drive. I tried installing it on an old Thinkpad laptop with Windows 95, but couldn't free enough conventional memory without disabling CD-ROM drivers that the game needs to run. Plus those drivers use this 16-bit DOS extender (CARDXTND.SYS) which is incompatible with any protected-mode apps.
Somebody please help.
Reply 1 of 18, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
For the dosbox approach you should give us the mountings you tried, or even better read and follow the 60 seconds guide in the dosbox part of this forum.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 18, by shotzo
I created an installation directory (C:\ULFOOTBALL) and mounted it as C. Then I mounted my CD drive as D. I can run the install program off the disk, but it claims to not detect the CD drive at all.
Reply 4 of 18, by shotzo
Ok, so how does that work? I typed HELP /ALL and couldn't find it in the list of DOSBox commands.
BTW, I heard the very good suggestion that I use my Windows 95 laptop with CONFIG.SYS disabled, since Windows doesn't need DOS drivers to run and not loading them may free memory up. I likely will still need to create a skeleton one with HIMEM and EMM386 so the game can use EMS memory though.
Reply 6 of 18, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Reply 7 of 18, by shotzo
Ok, I did the MSCDEX trick and got DOSBox to recognize the CD, but now I have a new problem. I run the game's install program and get the following message:
THIS GAME REQUIRES 100000 BYTES OF FREE DISK SPACE. YOU HAVE 0 BYTES.
BTW, you also mentioned using the LABEL option with the CD. Turns out the game disk has no volume ID. Weird.
Reply 8 of 18, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Adding "-t cdrom" to your mount line? More like correct procedure than a trick.
There's a workaround in this thread: "...needs 0 bytes", so won't install? (Machiavelli The Prince)
Reply 9 of 18, by shotzo
Ok, so the installer is trying to use some unsupported DOS function calls. I will have to try the program included in the thread.
Reply 10 of 18, by shotzo
The game installed successfully, but I'm still getting a "Cannot find the CD!" message.
Reply 11 of 18, by shotzo
As I mentioned earlier, I suspect that this is because of the game CD having no volume label.
Is there a workaround for this?
Reply 12 of 18, by ripsaw8080
Rank DOSBox Author
DOSBox Author
There is a patch on the Patches Scrolls site for Ultimate Football '95 that says it is a "CD not found" fix. Sounds like it's worth trying. 😀
There also appears to be an update for the digital sound drivers.
Reply 13 of 18, by shotzo
Ok, I did all that and got the game to run. However, the sound is not working correctly for some reason. I can faintly hear the game music and SFX under this continuous loud noise that sounds like a diesel engine running (I did download the driver update mentioned in here).
Is this a problem with the game or is there some DOSBox setting I have to adjust?
Reply 14 of 18, by ripsaw8080
Rank DOSBox Author
DOSBox Author
You're right, that is indeed an annoying sound, and appears to be an issue related to EMS that I'll report to the DOSBox devs in more detail. It looks like SB is the only supported digital sound option, and disabling it in the install is the easy (but unsatisfying) solution. There is a solution that will require a bit more effort, but maybe the game is worth it for you.
The workaround is to provide EMS memory to the game using the JEMM memory manager available here. It is possible to use JEMM386.EXE with XMS provided by DOSBox, but I think it will work best to have all memory management done by JEMM, so use JEMMEX.EXE from the binary archive. Set the DOSBox config to ems=false, xms=false, umb=false, and then run JEMM like this: JEMMEX FRAME=E000 LOAD (ignore the pageframe warning). The SB sound should be OK with this.
Reply 15 of 18, by shotzo
Ok, that fixed it. It also solved another question I had forgotten to ask about, which was that the animation became incredibly slow and choppy when I got into action mode.
Geez, what an annoying, high-maintenance game to set up. I would have liked to run it on my Windows 95 laptop except that it's seemingly impossible to free enough conventional memory. Then again, this was the first time I'd ever tried to run anything above 16-bit real mode games on DOSBox, and I guess I wasn't prepared for the much greater demands of 32-bit stuff.
BTW, I think this is a real-mode game that only uses EMS ala Day of the Tentacle and Colonization. I certainly don't see any message about DOS4GW when I start it up.
Reply 16 of 18, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Yes, it runs in real mode and uses plain EMS function calls, but it may be relying on DMA handling found only in EMM386 and similar memory managers. At any rate, it's good that all your effort to get the game running finally paid off. 😀
Reply 17 of 18, by bsevan00
i have installed the game but can't play it in action mode. keep getting error #131 uniforms sprite25.hom. What does this mean and how can I fix this?
Reply 18 of 18, by buckeye
ripsaw8080 wrote on 2011-04-17, 09:48:
Thanks ripsaw8080! Driving myself nuts trying to get this game to run on DBGL. Took me a bit to apply what you outlined but finally got it working by loading Jemmex in the autoexec section (after dosbox loads). Wonder what the usual practice was back in the day when the game came out to getting it running on real hardware.
