DOSBox debugger
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Re: DOSBox debugger
Postby wd » 2010-12-14 @ 07:32
Try the freedos debug.exe, or get a debugger-enabled build of dosbox.
wd
DOSBox Author
Re: DOSBox debugger
Postby hookersuper » 2011-4-12 @ 13:27
DOSBOX debugger (installer 0.72) does not run in Windows 7.
WHY?
Look at the attached JPG. If u don't speak Russian - the alert says:
"The program "DOSBOX emulator" does not work and will be closed.
Click to close it."
(46.7 KiB) Downloaded 748 times
hookersuper
Re: DOSBox debugger
Postby Qbix » 2011-4-12 @ 14:24
I'll add creating a debugger version of 0.74 to my to do list.
I'll try to have it done this week.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Re: DOSBox debugger
Postby Qbix » 2011-4-21 @ 15:12
User avatar
Qbix
DOSBox Author
Re: DOSBox debugger
Postby jefferl » 2011-10-09 @ 07:42
dosbox debugger would not work on DeskTop' resolution 800x600.
caused by can't allocate extra row for output windows ..
1024*768 is work fine.
jefferl
Re: DOSBox debugger
Postby wd » 2011-10-09 @ 10:38
Get a new gfx card+monitor.
wd
DOSBox Author
Re: DOSBox debugger
Postby egons » 2011-11-22 @ 15:01
all things what i want from debugger:
1. conitional BP's like bp if edx=value. this feature supported in Syser kernel debugger.
2. dump VGA palette. it would be great, tired of catching some palettes.
256bytes.net - demos all-in-one
egons
Re: DOSBox debugger
Postby aqrit » 2013-4-20 @ 05:15
of interest,
IDA DOSBox debugger plugin
https://github.com/wjp/idados
http://efry.users.sourceforge.net/idados/ ( old )
aqrit
Re: DOSBox debugger
Postby mwinter » 2013-7-25 @ 13:51
I've found the heavy debugger to be incredibly useful for interrogating old assembly code of mine. I've noticed however that when single-stepping through a program, the dosbox display doesn't seem to update regularly. This can be frustrating when dealing with more complicated c-code because, for example, I tend to have to wait for an indeterminate amount of time to see a printf output.
Looking through the code it seems that the debug loop doesn't regularly call the render updates, which seem to all stem from VGA_VerticalTimer. Since this also adds several PIC events I can see why it would be a potential problem to have that regularly run while debugging, but would it be possible to force a display update with a command in the debug window? Is it in fact dangerous to run VGA_VerticalTimer while the debugger is broken on a line?
Thanks,
-Mark Winter
mwinter
Re: DOSBox debugger
Postby Qbix » 2013-7-25 @ 14:24
did you use core=normal ?
User avatar
Qbix
DOSBox Author
Re: DOSBox debugger
Postby mwinter » 2013-7-25 @ 15:27
I was using auto, however a quick test with core=normal exhibits the same behavior. Specifically, the the dosbox window won't change after single-stepping over a "printf" call and in fact the only way to get an update seems to be to set a breakpoint past some code which takes a bit more time to run and hit F5.
In this case I'm testing with some straight c code compiled with borland turbo-c 2.01. Digging far enough down, the screen print inside the printf is an "INT 21h,AH=40h," dos write-to-file call with stdout (0x01) as the file handle. I believe the behavior on a direct write to video memory is the same though.
-Mark Winter
mwinter
Re: DOSBox debugger
Postby Qbix » 2013-7-25 @ 16:06
ah you mean the main window, not the debug window.
Indeed, that one needs vga events to trigger. You could if your code allows it, fire a timerirq. There is a debug command for that.
User avatar
Qbix
DOSBox Author
Re: DOSBox debugger
Postby mwinter » 2013-7-25 @ 16:17
Qbix wrote:ah you mean the main window, not the debug window.
Yes, sorry for the confusion and I'll give timerirq that a try, thanks.
-Mark Winter
mwinter
Re: DOSBox debugger
Postby Zyxel » 2013-11-24 @ 00:58
Is this a "Heavy Debug" Win32 version or a regular "Debug" version of DosBox 0.74?
Zyxel
Re: DOSBox debugger
Postby ripsaw8080 » 2013-11-24 @ 01:22
Debugger builds provided by Qbix are probably "heavy"; few bother with the middle ground. However, if you want to know for sure in any debugger build, there will be memory-change breakpoint commands (BPM/BPPM/BPLM) and CPU logging commands listed when you use the HELP command in the debugger.
User avatar
ripsaw8080
DOSBox Author
Re: DOSBox debugger
Postby Zyxel » 2013-11-26 @ 12:01
ripsaw8080 wrote:Debugger builds provided by Qbix are probably "heavy"; few bother with the middle ground. However, if you want to know for sure in any debugger build, there will be memory-change breakpoint commands (BPM/BPPM/BPLM) and CPU logging commands listed when you use the HELP command in the debugger.
Thanks for your help,
The Win binary executable, that I was referring to, indeed offers the BPM/BPPM/BPLM commands, so according to this criteria - this is an indication that this binary is the "Heavy Debug" version.
BTW: Do you know of any document that describes the functionality of debugger commands. I am teaching basic assembler to some young students and such description of debugger commands would come in really handy.
I tried the DosBox Wiki at:
http://www.dosbox.com/wiki/Main_Page
...but I could not find any descriptions of the debugger commands there, e.g. the path where the HEAVYLOG command saves its results, etc...
Zyxel
Re: DOSBox debugger
Postby ripsaw8080 » 2013-11-26 @ 12:53
There's a guide for the debugger in the guides section, but it's rather ancient, so might not be 100% accurate now. The guide is not in-depth; some familiarity with concepts found in other debugging environments is assumed. You can refer to the debugger source code for specifics that aren't obvious, if needed.
User avatar
ripsaw8080
DOSBox Author
Re: DOSBox debugger
Postby Allegro » 2014-4-28 @ 15:21
Hi all,
I am newbie on this forum and in dosbox development (and honestly in xNIX as well) so please be polity for my presumaby stupid questions.
I've tried to compile dosbox on Win 7, using latest MinGW/MSYS and pdcurses 3.4 with heavy debug option turned on. everything went fine but when debugger activated none of extended keys (arrow keys, Insert/Delete/Home/End/Page Up/Page Down) works. I've tried to use both latest SVN and RELEASE 0.74 revisions, but the result is the same. Digging into source code and debugging shown that funtion toupper changes correct key returned by getch function to wrong one for extended keys. For example: KEY_UP (0x103) turns into 0x3. What may be the reason of such odd behavior?
Allegro
Re: DOSBox debugger
Postby klise » 2014-7-19 @ 04:16
I'm so happy I've successfully compiled DosBox 0.74 heavy-debug version in Visual C++ 2010 Express, the source code downloads from
http://source.dosbox.com/dosboxcvs.tgz
and I've seen the debugger help text, which is the newest, and it's quite different from the old guide of
http://www.vogons.org/viewtopic.php?t=3944
I'm so glad that BPINT command now has included an AL parameters, not only an AH like the older version.
Here is the inner help text of this newest DosBox 0.74 Heavy-Debug version:
Debugger commands (enter all values in hex or as register):
F3/F6 - Previous command in history.
F4/F7 - Next command in history.
F5 - Run.
F9 - Set/Remove breakpoint.
F10/F11 - Step over / trace into instruction.
ALT + D/E/S/X/B - Set data view to DS:SI/ES:DI/SS:SP/DS:DX/ES:BX.
Escape - Clear input line.
Up/Down - Move code view cursor.
Page Up/Down - Scroll data view.
Home/End - Scroll log messages.
BP [segment]:[offset] - Set breakpoint.
BPINT [intNr] * - Set interrupt breakpoint.
BPINT [intNr] [ah] * - Set interrupt breakpoint with ah.
BPINT [intNr] [ah] [al] - Set interrupt breakpoint with ah and al.
BPM [segment]:[offset] - Set memory breakpoint (memory change).
BPPM [selector]:[offset]- Set pmode-memory breakpoint (memory change).
BPLM [linear address] - Set linear memory breakpoint (memory change).
BPLIST - List breakpoints.
BPDEL [bpNr] / * - Delete breakpoint nr / all.
C / D [segment]:[offset] - Set code / data view address.
DOS MCBS - Show Memory Control Block chain.
INT [nr] / INTT [nr] - Execute / Trace into interrupt.
LOG [num] - Write cpu log file.
LOGS/LOGL [num] - Write short/long cpu log file.
HEAVYLOG - Enable/Disable automatic cpu log when dosbox exits.
ZEROPROTECT - Enable/Disable zero code execution detection.
SR [reg] [value] - Set register value.
SM [seg]:[off] [val] [.]..- Set memory with following values.
IV [seg]:[off] [name] - Create var name for memory address.
SV [filename] - Save var list in file.
LV [filename] - Load var list from file.
ADDLOG [message] - Add message to the log file.
MEMDUMP [seg]:[off] [len] - Write memory to file memdump.txt.
MEMDUMPBIN [s]:[o] [len] - Write memory to file memdump.bin.
SELINFO [segName] - Show selector info.
INTVEC [filename] - Writes interrupt vector table to file.
INTHAND [intNum] - Set code view to interrupt handler.
CPU - Display CPU status information.
GDT - Lists descriptors of the GDT.
LDT - Lists descriptors of the LDT.
IDT - Lists descriptors of the IDT.
PAGING [page] - Display content of page table.
EXTEND - Toggle additional info.
TIMERIRQ - Run the system timer.
HELP - Help
Edit by Qbix: Update archive location to prefered location
klise
Re: DOSBox debugger
Postby klise » 2014-9-14 @ 05:40
Hello, Qbix,
I've compiled doxbox successfully via MinGW+MSys in my Windows XP, event the heavy-debugger too. It needs SDL library for dosbox, and "pdcurses" for the debugger, to complete the works. I think I should post a topic to write down these steps so the others can save their time when they try to do this at next time.
Here I encounter a problem, that the dosbox.exe is 14,033KB big, and the heavy-debugger is 14,590KB too. I think it maybe contains much more "in-line debugging information" inside the EXE file. I'm working in Windows so I'm no so farmiliar to *nix, so how can I reduce the size of the output EXE file ?
P.S:
My dosbox version is : http://source.dosbox.com/dosboxsvn.tgz
klise
PreviousNext
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 0 guests
cron
