First post, by DosFreak
http://www.classicdosgames.com/
1 April 2011
I am pleased to announce that we have replaced JPC with a Java version of DOSBox to make DOS games playable in your browser! Speed and compatibility are almost perfect in every game. Paganitzu and Wolfenstein-3D are finally playable, and games that used to play slowly, like DOOM and Heretic, now play at full speed (assuming that you have a modern computer and browser). JPC's PC Speaker emulation has been replaced with full Sound Blaster sound! Now you can play Drum Blaster in your browser. And check out how awesome Duke Nukem II sounds! I'm adding new games as fast as I can (200 and counting!). Check it out!
http://www.classicdosgames.com/online.html
Press the gamepad to play the shareware games!
Make your games work offline
Reply 1 of 6, by wd
Rank DOSBox Author
DOSBox Author
Cute.
Reply 2 of 6, by collector
I like.
Reply 3 of 6, by eL_PuSHeR
This is cool. 😎
Reply 4 of 6, by Mau1wurf1977
WOW!
This is better than sliced bread!
Reply 5 of 6, by DosFreak
Update
I am pleased to announce that we have replaced JPC with a Java version of DOSBox to make DOS games playable in your browser! Speed and compatibility are almost perfect in every game. Jump 'n Bump, Paganitzu, and Wolfenstein-3D are finally playable, and games that used to play slowly, like DOOM and Warcraft: Orcs & Humans, now play at full speed (assuming that you have a modern computer and browser). JPC's PC Speaker emulation has been replaced with full Sound Blaster sound! Now you can play Drum Blaster in your browser. And check out how awesome Duke Nukem II sounds! I'm adding new games as fast as I can (200 and counting!). Check it out!
Reply 6 of 6, by njaydg
Although I prefer the DOS interface, this should please a lot of DOSBox novice users.
Amazing nevertheless! 😎
