File not found ?
First post, by Decop
Hello !
I threw DOSBox 0.74 and I have a message mistake:
Z:\>mount E E:\Rimini_V
Drive E is mounted as local directory e:\Rimini_v
Z:\>E
E:\>Dir
RIMINI.BAT
RIMINI_V.EXE
RITEXTD.TXT
E:\>Rimini
Data E:\RIMINI_V\RITEXTD.TXT not fund??????
The file exists = to see annex
Do you have an answer?
Thank you
Reply 1 of 4, by leileilol
Ok this is an absolute path issue (did you install it within DOSBox?). try this
Make a E:\DOS directory, and move the Rimini_V folder into it
Mount E: to E:\DOS
E:
cd Rimini_v
rimini
Debian's fucked
Reply 3 of 4, by SKARDAVNELNATE
Decop wrote:
The file exists
No, it doesn't. In your example E:\RITEXTD.TXT exists. E:\RIMINI_V\RITEXTD.TXT does not.
Reply 4 of 4, by Decop
Hello !
Thank you for your precious help!
all functions
