First post, by morgana_ravens
I can't get the game to play using DOSBox. I'll go through the steps through Setup, but it'll tell me to put in the CD, which it already is but it doesn't notice it. What should I do?
Reply 1 of 7, by SKARDAVNELNATE
Setup is not Install. Did you run Install first?
Reply 2 of 7, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Reply 3 of 7, by morgana_ravens
yeah, it's installed
Reply 4 of 7, by bloodbat
Your mounts?
Reply 5 of 7, by morgana_ravens
mounts??
Reply 6 of 7, by wd
Rank DOSBox Author
DOSBox Author
Yeah.
Also: -> README
Reply 7 of 7, by SKARDAVNELNATE
morgana_ravens wrote:
mounts??
Yes, mounts. You said it's installed. Now describe what steps you took to install it.
