First post, by retro games 100
Introduction
I am testing a Creative SoundBlaster 2.0 8-bit ISA sound card.
1) Link to the Deluxe (but older) SoundBlaster 2.0 DOS and Windows 3 driver files - but read note 1 below! Filename is "SoundBlaster 1.0 CT 1350B Install Disks.rar". Source: Malik's SoundBlaster mediaFire downloads page.
2) Link to the more recent SoundBlaster 2.0 DOS and Windows 3 driver files. Filename is "SoundBlaster 2.0 CT 1350B Install Disks.rar". Source: Malik's SoundBlaster mediaFire downloads page.
3) Link to the SoundBlaster driver and software update package. Filename is "SoundBlaster 2.0 Updated Dos Win3.11 Drivers.rar". Source: Malik's SoundBlaster mediaFire downloads page.
4) Link to another SB2 driver package. See note 4 below. Filename is Sblast2.zip.
5) Link to the Stason jumper specification webpage for this sound card.
Notes
1) I couldn't get this package to work 100% with my CT1350B revision 4 card. The DOS installation works, but not the Windows 3 installation. Something isn't quite right. I think this software is for the "deluxe" SB2. I don't know why this doesn't appear to work for my SB2. I tried to install it twice - the second time I tried, I used a completely fresh install of DOS and Windows (3.11 / wfwg). I couldn't get the digital sound to work in Windows. There seemed to be no hardware conflicts. I don't think the Windows 3 software installation was fully successful. I read the FAQ readme files, but none of their suggestions worked.
Please note that this package contains older drivers compared to the software package in download link number 2 above, so I wouldn't spend too much time with it. A good thing about this package is the "deluxe" extras you get to use in DOS. This includes a DOS-based talking Parrot demo (not the "Parrot 2" software for Windows), and a version of "SB talker" that pretends to be a doctor. There is also a multimedia presentation demo. Fun stuff! 😀
Conclusion - install the DOS software only from this packge, and don't install anything for Windows 3, then put it to one side on your HDD (ie rename the C:\SB to something else), then install the software in link number 2, so that you get the non-deluxe software installed to C:\SB, but that software uses the updated files, and also the Windows software will work correctly.
Also, this contains older software for Monologue, version 1.5. You can get an update for this, found in link number 4 above. I wonder if this deluxe software is for an old 8-bit SB *Pro* card, rather than a SB 2.0 card? However, I distinctly remember the DOS install screen saying SoundBlaster 2.0 on it, so perhaps it was for a SB2 card with extra chips on it? I notice that other deluxe extras in the C:\SB folder are for multimedia demos, but the weird thing is that this installation does not add the multimedia drivers drivers to the config.sys file. OTOH, the updated software (not deluxe) does add these MM drivers. Strange.
2) All of this software worked in both DOS and Windows 3. It also contains more recent driver files compared to the software in link number 1 above. I recommend that you use this software for both DOS and Windows. You can then run the update, found in link number 3 above, and explained below.
3) This will update all of your DOS and Windows SB2 files. I tested this, and it worked. Copy all of these files to a floppy disk, and run install. The install program will identify your soundcard, and update only the relevant files on your HDD.
4) I used this software to install the updated Monologue for Windows (version 1.7), and also the SB Talker DOS program. Please read the included readme file for installation instructions. The other disk1 to 4 stuff is the same as the software in link 2 above, and so you can ignore it.
5) The "undocumented / tech support testing" jumpers near the output jacks are not documented.
Recordings
2.5 minute recording here. Includes the "deluxe" multimedia demo (recording only), DOS talking parrot, SB Talker, and a tune played from the SB Windows 3 MIDI file player.
Using it in Windows 3
Using the software in link 2 above (and not link 1 above), there's more updated software to use.
Hehe!
Time to make the coffee!
The card
That's curious. On the back of this CT1350B card, there's a sticker saying it's a CT1350A card. Perhaps this is the reason why the "deluxe software" in the downloads link 1) area above didn't work with this card?
Reply 1 of 9, by TheMAN
I think this has something to do with the DSP revision... the older drivers don't work because it can't talk to the newer card.... the SB 2.0 is very different from the SB 1.0 as we all know (not as big of difference between SB Pro 1.0 and 2.0 though).... I doubt this has anything to do with the CMS chips... the drivers doesn't care about it, and any CMS bullshit predates Windows 3.1 anyway and will be DOS only... and the DOS CMS drivers don't get loaded on bootup from what I understand... you have to run it separately or let whatever game use its own built in drivers
AFAIK, all of the SB 2.0s have at least DSP 2.0... the SB 1.0s rarely have the DSP 2.0... DSP 2.0 allows auto DMA init
Reply 2 of 9, by retro games 100
I think the filename for the software in download link #1 above has been labelled incorrectly. At the moment, it says "SoundBlaster 1.0 CT 1350B Install Disks.rar". Perhaps the CT model number is incorrect. Perhaps this software is for the SB 1.0, and consequently, the CT model number is wrong? I think 1350B is for SB 2.0. But the really weird thing is that when I ran this software, the install program said "SB 2.0" on the screen.
Reply 3 of 9, by TheMAN
I tend to trust the PCB label more than the stupid FCC label
look at the disk.id file and see what the SKU code says... it's the only for sure way to id these disks that were never imaged properly (which is why I like to image disks and not just slap them into a zip file)
Reply 4 of 9, by sklawz
hi
i have a card which appears to be just a relabeled version of this:
Reply 5 of 9, by sklawz
a file on the net called qs803drv.exe contains the following:
~/Downloads> lha l qs803drv.exe
PERMSSN UID GID SIZE RATIO STAMP NAME
[generic] 625152 100.0% Jan 9 1995 sb2up.exe
[generic] 57984 96.6% Jan 18 1995 sb15wu.exe
[generic] 77440 98.1% Jan 18 1995 testsb.exe
Total 3 files 760576 99.6% Apr 9 06:02
not sure what they are but will investigate at a later time.
bye
Reply 6 of 9, by sklawz
here is the content:
Archive:  ./sb15wu.exe
��ذ�����������������������������������������������������������۲�����ص
��ذ��� � Creative Bulletin Board System � USA � 24 Hours ���� �ص
��ذ��� � [405] 742-6660 v.32bis/14.4K � ���� �ص
��ذ��� Sound Blaster .... the BLAST heard 'round the WORLD! ���� �ص
��ذ�����������������������������������������������������������۲�� �ص
������ �ص
����������������������������������������������������������������������ص
�������ذ��۲����۲���۲���۲���۲���۲���۲���۲���۲���۲��� �������ص
�ر������� The People Who Brought You - SOUND BLASTER - ����������ص
�ر��� ���۲����۲���۲���۲���۲���۲���۲���۲���۲���۲��� ���� ص
�ر��� ���� ص
�ر��� Sound Blaster(tm) North & South America Support Center ���� ص
�ر��� ���� ص
�ر��� Product Patches & Drivers Updates ���� ص
�ر��� Now also providing product info on new products! ���� ص
�ر��� ͹ Towards Better Customer Support ! �� ���� ص
�ر��� ���� ص
�ر��������۲��������۲��������۲��������۲������������������������� ص
����� ص
Instructions: Please type " README " for further installation details.
����������������� [ Creative BBS/USA Disclaimer ] ������������������
Please make sure that you do not alter or modify the files/drivers
within before uploading the file to other BBSes. If the file has
been tampered with, please call our BBS listed above to obtain the
latest copy. Creative Labs, Inc. (CLI) and Creative Technology Ltd.
(CTL), declares no responsibility for damages done or other
expenses due to the use of any of these files incase the file
has been tampered with.
������������ � CREATIVE BULLETIN BOARD SYSTEM / USA � ������������
Length Method Size Cmpr Date Time CRC-32 Name
5640 Defl:X 1964 65% 1992-05-15 11:33 868564cb VSBPD.386
14896 Defl:X 8923 40% 1992-05-15 09:11 b0a64a3f SB15SND.DRV
334 Defl:X 193 42% 1992-05-04 19:39 08f332a2 OEMSETUP.INF
40962 Defl:X 3203 92% 1992-05-04 08:57 10d86b01 MIDIMAP.CFG
12416 Defl:X 7012 44% 1992-04-28 19:05 0ded33fc SBFM.DRV
22016 Defl:X 6446 71% 1992-04-10 15:24 a9a0ee15 MMJBOX.EXE
22016 Defl:X 6471 71% 1992-03-28 08:48 66ebdfd0 MMCBOX.EXE
2025 Defl:X 1594 21% 1992-10-08 00:16 90cfe7a6 README.COM
12192 Defl:X 3493 71% 1994-03-25 14:27 1e880fa4 README.TXT
132497 39299 70% 9 files
Archive: ./testsb.exe
������ �ص
…Show last 85 lines
�ر��� ���� ص
�ر��� ���� ص
�ر��� ���� ص
����� ص
42112 Defl:X 30221 28% 1992-04-17 15:17 961fc08b TEST-SBC.EXE
47804 Defl:X 28785 40% 1992-04-17 14:46 2d4e0203 FMORGAN.EXE
860 Defl:X 456 47% 1994-06-28 18:58 5a832d30 README.CLI
90776 59462 35% 3 files
Archive: ./sb2up.exe
������ �ص
�ر��� ���� ص
�ر��� ���� ص
�ر��� ���� ص
����� ص
122 Defl:X 90 26% 1995-01-13 14:29 7f6e5c5b DISK.ID
196317 Defl:X 147697 25% 1994-10-14 04:26 ae413fbf INSTALL.EXE
16043 Defl:X 4182 74% 1995-01-10 02:00 e7393c45 README.TXT
23380 Defl:X 22748 3% 1994-10-10 01:02 5cb3a13d INSTALL.PVL
5639 Defl:X 2531 55% 1995-01-13 14:49 118fdee9 LICENSE.TXT
17258 Defl:X 17008 1% 1994-03-22 01:00 cc4913dc SBSIM.PVL
2025 Defl:X 1594 21% 1992-10-08 02:20 90cfe7a6 README.COM
179499 Defl:X 175639 2% 1995-01-10 02:00 fe67fde0 S2DOSDRV.PVL
10975 Defl:X 10804 2% 1994-10-10 01:02 15070505 S2WINDRV.PVL
111997 Defl:X 109231 3% 1994-10-10 01:01 0479dad6 VOCUTIL.PVL
79634 Defl:X 79356 0% 1994-08-03 01:01 19ae894e SOUNDOLE.PVL
35288 Defl:X 35065 1% 1994-03-22 01:00 098ee507 MMPLAY.PVL
364 Defl:X 213 42% 1995-01-13 15:46 6143d119 FILE_ID.DIZ
678541 606158 11% 13 files
Reply 7 of 9, by TheMAN
nothing really special about those files... they're just the basic drivers that was available on creative labs ftp/bbs more than 10 years ago... the real driver disks have actual apps and utils; stuff you couldn't just download
Reply 8 of 9, by leileilol
that's true. and the sb20 from 1991 wouldn't have this Windows app suite you would see. it'd have some silly text to speech stuff like Dr. Sbaitso, a talking Parrot, and some intelligent pianist organ (very Microsoft SongSmithish). and some voc editing tool. and some cmf demonstrations.
has those two floppies ever been uploaded? If not, I can try digging FAR DEEP for them. I don't even know where my card is!
Reply 9 of 9, by retro games 100
Some noticeable differences between two SB 2.0 cards. I very vaguelly recall that the "clone chips" card sounded clearer than the "Yamaha chips" card.
