First post, by okrist
Hi
I've managed to install the game in dosbox, but i get this message when i try to run the game:
"Error: Could not open the configuration file CONFIG.DAT. This file is required for the game to run correctly. Please check your installation."
And "Stack fault".
Can anybody help me?
Reply 1 of 7, by IIGS_User
Any mount differences between the install and the run?
Klimawandel.
Reply 2 of 7, by Gamecollector
Championship Manager 2 is LaserLok protected game. With "no cd in drive" message in dosbox.
So - it looks like you use abadonware version.
Did you OWN the game?
Reply 3 of 7, by okrist
Yes, I own the game, I use the original CD-rom.
Reply 4 of 7, by okrist
I'm new to dosbox and I'm not sure I understand your question. Here's what i did to install the game:
1: I created a folder for my game: C:\Users\your-user-name\Documents\CM2
2: I inserted the CD (original)
3: In dosbox: Z:\>mount C "C:\Users\your-user-name\Documents\CM2
4: Z:\>mount D "E:\" -t cdrom (e: is my real cd-drive)
5: Z:\>C:
6: Z:\>D:
7: D:\>install
8: D:\>go (I get the error message).
Reply 5 of 7, by Gamecollector
Step 8:
c:
cd cm2
go
You must run the game from game directory, not from cd.
Still the result is "Checking cd... Stack overflow" after the intro movie. Because of LaserLok.
Reply 7 of 7, by okrist
Thanks a lot! I works now 😀
