First post, by Jivren
Playing wolfenstein or blake stone the keys end up stuck turning left when I use multiple keys at once. Anybody else have this prob?
Reply 1 of 7, by Jivren
It's really random when it actually sticks. Stops sticking when I press another button.
I have a dual core processor in my dell laptop with an ati integrated graphics card.
I was just gonna play through the whole game and ignore it but seeing as it does the same thing on blake stone I assume its a problem with dosbox and I thought I would ask.
Reply 2 of 7, by VileR
does it still happen if you reassign the movement/turning keys (e.g. use the keypad, or a completely different place on the keyboard)?
how about playing with the cycles?
Reply 3 of 7, by Jivren
Set the keys to I K J L and yeah it still did the same thing. Played with the cycles a tiny bit, but could try experimenting with em a little more.
Wonder if dosbox might have a limit to how many keys that it can handle being pressed at a time?
I'd just use a mouse instead but I'm using a touchpad so yeah.
Reply 4 of 7, by Jivren
btw it does the same thing in doom. Just confirming that it's not just wolfenstein, and blake stone.
Reply 5 of 7, by Jivren
I was just now playing zone66 and in the menu's the keys get stuck so its not just the left and right keys.
Reply 6 of 7, by VileR
I'd suggest looking up a keypress test utility (one of those things that show you on-screen which keys are pressed/released), there should be many of those for all operating systems. Run one in DOSbox, run one natively on your host OS, see if in any/both cases it fails to take note of released keys.
Maybe do a quick web search and check whether SDL has known problems with the keyboard on your specific laptop model and OS.
Reply 7 of 7, by Jivren
Vilerancour thanks for your help. I ran it at 19000 cycles and that seemed to fix it. I'll try the keypress util if I run into a problem again. 😀
