Tandy Sound Question
First post, by TheAlmightyGuru
There are two Tandy sound devices, the 3-voice speaker and the DAC, but as far as I know there is only one Tandy sound setting.
How can I know when specific Tandy sound devices are enabled?
Is there a way to turn on just the 3-voice chip, or just the DAC?
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
You can't. Set machine=tandy and you have 3voice+tdac.
Reply 2 of 4, by TheAlmightyGuru
Thanks for the info.
Is there any way to tell which one is outputting data at any given time? I know I can tell the difference between MIDI or OPL by logging them, can I do that with the 3 voice and the DAC?
Reply 3 of 4, by wd
Rank DOSBox Author
DOSBox Author
You'd have to put some logging into dosbox, but in general tandy DAC usage is pretty rare anyways.
Reply 4 of 4, by TheAlmightyGuru
Thanks for the input wd!
