First post, by sliderider
- l33t++
Has anyone done this? Is there a way to use the onboard video ONLY for 2D and have all games utilize the Voodoo2?
wrote:Has anyone done this? Is there a way to use the onboard video ONLY for 2D and have all games utilize the Voodoo2?
I thought Voodoo 2 only did Glide?
Roughly a decade ago I had a similar configuration (using an onboard Rage II+ along with a Monster 3D II), running under Windows 98 SE. As far as I remember the Voodoo2 card took over all 3D functions, including Direct3D games.
What seems to be the problem?
GUIs and reviews of other random stuff
Вфхуи ZoPиЕ m
СФИРEt. SEPOHЖ
Chebzon фt Ymeztoix © 1959 zem
wrote:wrote:Has anyone done this? Is there a way to use the onboard video ONLY for 2D and have all games utilize the Voodoo2?
You can play opengl games with Voodoos.
wrote:Roughly a decade ago I had a similar configuration (using an onboard Rage II+ along with a Monster 3D II), running under Windows 98 SE. As far as I remember the Voodoo2 card took over all 3D functions, including Direct3D games.
The problem is with non-Glide games the system is dog slow like the Rage is running the games instead of the Voodoo. Where should I be looking to make changes to make sure that all games run through the Voodoo instead of the Rage?
wrote:wrote:Roughly a decade ago I had a similar configuration (using an onboard Rage II+ along with a Monster 3D II), running under Windows 98 SE. As far as I remember the Voodoo2 card took over all 3D functions, including Direct3D games.
Exchange the Rage for a 2D only card? That way if a game works, it's got to be the Voodoo 😁
wrote:wrote:wrote:Roughly a decade ago I had a similar configuration (using an onboard Rage II+ along with a Monster 3D II), running under Windows 98 SE. As far as I remember the Voodoo2 card took over all 3D functions, including Direct3D games.
Yeah, that sounds like a good idea. I'm going to have to dig out my Tseng, I guess, and see if that does anything.
wrote:wrote:wrote:The problem is with non-Glide games the system is dog slow like the Rage is running the games instead of the Voodoo. Where should I be looking to make changes to make sure that all games run through the Voodoo instead of the Rage?
Perhaps an easier way would be to start up a game, then remove the passthrough cable?
That 3D Control Center linked to on the PowerVR Fun Thread may help you sort your Direct3D HAL problem.
I had a very similar setup once as well.
For OpenGL games, you need to copy the file 3dfxvgl.dll (which I think is normally found in system32) to the directory of the game's executable and rename it to opengl32.dll . You might also manage to do something with WickedGL, but I didn't mess around much with that.
DirectX games are a little more complicated. It's possible to switch back and forth between the cards in some situations; I forget what the utility I used was called, but all it really did was rename a particular registry key. I think there's a problem if you're using the last official drivers for the Rage card, however; since they support a later DirectX version than the Voodoo drivers, games will always default to using them.
wrote:Perhaps an easier way would be to start up a game, then remove the passthrough cable?
Aside from the monitor, I don't think any of the hardware actually cares if the passthrough cable is there or not.
For simplicity I always used Microsoft's drivers for the Rage. The extra stuff that came with ATI's drivers were of little use to me anyway.
Вфхуи ZoPиЕ m
СФИРEt. SEPOHЖ
wrote:wrote:Perhaps an easier way would be to start up a game, then remove the passthrough cable?
Unless it's the actual 3D card (and not the Voodoo 2) that's doing the 3D, right?
wrote:wrote:wrote:Perhaps an easier way would be to start up a game, then remove the passthrough cable?
I was trying to think how to respond to that and was getting confused, but if you unplug the passthrough and the game is still running on the monitor, then that would mean that the Rage is running it and not the Voodoo, right?
wrote:wrote:wrote:Aside from the monitor, I don't think any of the hardware actually cares if the passthrough cable is there or not.
The other way around. I understood that when the Voodoo 2 card is not active, it merely sends the signals it receives from the other card to the monitor without "touching" it.
If you're using a Voodoo 2 and play Glide, disconnecting the cable shouldn't do much, but browsing around in Windows and disconnecting the cable = monitor should display "No signal" 😉
Edit:With cable, I'm talking about the short passthrough cable that runs from the normal card to the Voodoo.
My guess here is that the Rage is taking the role of the primary DirectX Accelerator. You can either get software to reassign them (what leileilol was talking about with power strip,) or within some applications there will be an option to choose where it is to use the primary or secondary accelerator.
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
Come to think of it, I think 3D Control Center was the program I was using long ago.
If the question is how to test whether the Voodoo2 is being used, then yes, that would be one way of doing it. But I thought the question was how to make all games run through the Voodoo instead of the Rage, in which case the software isn't going to care if the passthrough cable is there.
The performance difference between a Rage and the Voodoo2 is so vast it would be hard to mistake them, I'd think.
Performance? Only if the game uses 4bit+ alpha blend channels (usually everything after...... roughly June 1998) you'll notice it tank.
Also, Voodoo2 has a distinctive filter on its DAC, so it's obvious when the Voodoo2 is used because the picture will appear blurry. There's also a default high gamma table.
If you need more help making it obvious, drop this in your AUTOEXEC.BAT:
SET FX_GLIDE_SHAMELESS_PLUG = 1
This will cause a 3dfx logo to appear in the bottom right
