First post, by AlexKitson
Is the program I want to open the wrong file type, have I made a mistake in the script, or have I done something else wrong?
Thanks.
Reply 1 of 4, by Vince.Bloodworks
you're just wrong with the command =P.
1) You're already in the folder ARSENAL(because you mounted it directly as C:)
2) You have to run the install program. So type "install" at the prompt.
3) You can execute everything with the extension *.EXE, *.COM or *.BAT
4) To see what you have to execute, just type "dir" at the prompt
Have fun
Vince
Reply 2 of 4, by AlexKitson
Thank you. It has worked 😀
Much appreciated.
Reply 3 of 4, by yelloe
hi... i have read your answer to someone who asked regarding his problem at dosbox... i am empressed with what u helped.. and just same problem i wanted to ask help from you..i am encountering trouble now in dosbox. at first i was so glad that i able to run my program at dosbox in windows 7, but eventually it just stop running at all..everytime i mounted the drive and at the bottom of window dosbox there it says "BOSS Stub Version 3.2 Copyright (c) 1990, 1991 Borland International".. and i think thats the one that blocks the dosbox from opening to c++ program.. but my problem is, what does that statement means?.. and how can i run again c++ from dosbox...
i would really appreciated any help coming from you.. please help me..
problem goes like this:
-- mounted d c:\
-- d:
-- cd tc
-- cd bin
-- tc or tc.ece
