First post, by Gambit37
Hi. I've just bought Glidos (even though I'm unemployed, £6 is a bargain), to play Tomb raider again.
I have one of the very earliest CDs of Tomb Raider and the Glidos logo appeared on the very first level, so I had to buy it...
Anyway, I'm trying to capture the textures as explained on the website, and although I have added the line: TextureOverride: Capture and played the whole of the first Caves level, nothing happens. I get no folder with images in.
Can any body help me sort this out. I'd love to design a new Hi-res texture pack for Tomb Raider, but it ain't gonna happen if I can't get it to work...
I'm running Windows XP Home on an AMD Athlon 1900+ with GeForce Ti 4600. Glido is installed on D:\Program Files\Glidos.
Thanks
Reply 1 of 5, by Gambit37
Hmmmm... seems to be working if I quit out of the game before completing a level. Does the folder get deleted when you switch levels?
Reply 2 of 5, by Glidos
No, the folders don't get deleted. I can't imagine what is making it fail. You need to actually view every texture to generate a complete starting pack, but you can do this in several playing sessions.
Let me know if you notice any other patterns to this stange behaviour.
Reply 3 of 5, by Gambit37
Seems to be OK now, though ocasionally it doesn't seem to work -- I think it's because I sometimes edit the INI file while Glide Server is running. If I click Start game again, it doesn't always work -- I guess this is because the INI file is only checked on Startup?
Haven't checked this consistently so it may just be me!
Reply 4 of 5, by Kaminari
You need to quit and relaunch Glidos every time you modify your ini file.
Reply 5 of 5, by Glidos
Oh, yeh. Well spotted. I ought to change that behaviour, or at least document it.
