First post, by Paddan1000
- Member
My Ensoniq Soundscape Elite, which has worked flawlessly until now, suddenly refuses to initialize when I run the initialization program ssinit.exe. All I get is the error message "Error: timeout waiting for DMA to complete". For a while it would initialize maybe one out of every five times I started the computer, but now the problem seems permanent.
I moved the card and the hard drive with the drivers to another computer, but the problem persisted. When I run ssinit.exe, the card is detected by the program, but when I choose to test the chosen IRQ or DMA channel, the program claims that they are "In Use" by something else, regardless of which ones I chose. I've tried to change all the system resources, but that didn't make any difference. I've alsy carefully inspected the surface of the card to look for cracks, but there were none serious enough to have damaged the circuits.
What is the problem and can it somehow be fixed? Could the hard drive with the drivers be the source of the problem, rather than the sound card?
