First post, by oo_500
I'm embarrassed I have to ask, but I can't get the damn thing to work.
I want to play a game with a filter, should be easy right? Well there is no "scaler=" line in my default config and if I add one (like "scaler = scan3x" under [render]) it is deleted as soon as I run D-box, as if I'd entered something erroneous!
What is up with this, help!
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
don't use that frontend, but a better one that support it.
Water flows down the stream
Reply 3 of 7, by wd
Rank DOSBox Author
DOSBox Author
This is unrelated to dosbox though, if your frontend has some forum or the author is watching this thread you may get some help.
Otherwise try one of the other frontends, the popular ones certainly handle scalers correctly.
Reply 5 of 7, by oo_500
Well now I'm completely confused. I don't even understand what a frontend is nor why it is not working. Ugh, I've used a Nitendo DS emulator and a click of a button was enough to change a scaler.
collector wrote:
You can also just read the README to learn how to do it without a frontend. It really is pretty easy.
Solving the Rubik's Cube is pretty easy for some people, but not for me! I'd go insane reading through the whole readme and ctr+f only gave me this:
-version
output version information and exit. Useful for frontends.
Reply 6 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Collector didn't want you to read up on frontends but to read the readme so you don't need frontends.
If you are adament about frontends, go to dosbox.com click on faq and read the wiki on frontends.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 7, by oo_500
[edit... can't edit my post... Why is nothing working for me??]
Ooooh, you meant D-Box, damn, I thought of ask whether it could be causing this, but saw no reason why it would. Yeah, I'll try another one, hate writing dos commands. Thanks.
