First post, by rfnagel
This one isn't really all THAT old, but I figured maybe someone here could help (I also posted this over in the Steam forums).
I've recently started playing the Steam version of "Day of Defeat", and have been trying to create a server that some of my Intenet friends can join (so we can play DoD together, with me hosting the game). I have a DSL modem with a built-in wireless router, which is what my PC connects to the Internet with.
I start DoD, and then begin a new game ("Create Server"), and then go into the game. I then send an "Invite" to a buddy of mine who is online at the time, but when he attempts to join the game (accepts the invite), he gets the error message "Server is unavailable".
I've checked the DSL modem/wireless router's configuration, and have added the required entry to open the correct ports and such. Mine is a Westell VersaLink 7500 Gateway, and the built-in software in the firmware for it has options for "Enable an online game connection", and quite a few presets for various games (the one that I selected was "Half-Life Server").
Anyhow, when my friend(s) try to join a game that I've created (after sending them an invite), for my IP address they see 10.0.0.10:27015 ... which is weird, as that's the LAN IP for my PC.
I tried adding two lines to my Server.cfg and ListenServer.cfg files...
IP ###.#.###.##
port 27015
...with the "IP" entry being my actual Internet IP address as reported by the DSL modem's software ("WAN IP: ###.#.###.##").
Still no joy 😀 Any idea of how to kick this beast to get it working? Seems that it shouldn't be all THAT difficult <ugh>.
Thanks for any help 😀
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 1 of 6, by ADDiCT
http://www.portforward.com
1. find out which ports are used by DoD
2. disable your router firewall or open the DoD ports for incoming connections
3. forwards the port(s) to the internal IP of the machine hosting the game
4. enable incoming connections for the ports used by DoD on the host machine's firewall (or disable it)
5. look up your external IP (router interface or http://www.whatismyip.com) and tell your friends to connect via the game console (command usually "connect <ip/hostname>(:<port>)")
To make connecting easier you could use a service like dyndns, so your friends only have to remember your hostname, not your (probably dynamically assigned) IP.
Not that you could've found out all of that by using Google... (;
Not good, change back to defaults, or use the internal IP of the machine hosting the game. The game doesn't know about your external IP adress, just like Steam obviously doesn't.
Reply 2 of 6, by leileilol
also try sv_lan 0
Debian's fucked
Reply 3 of 6, by rfnagel
Thanks for all of the info, but AFAIK I have the ports forwarded properly (see attached pic).
I haven't tried that yet, but shouldn't it work if I "invite" them to join the game from within the game itself (via the in-game Steam client overlay)?
Mine is static, unless I renew/release the connection.
I've Googled until my brain hurts <grin>.
Part of the Google results (as well as Steam's support site) said to add those lines.
leileilol wrote:
also try sv_lan 0
I just found that via Google... will have to give that a try as well.
Rich ¥Weeds¥ Nagel
Reply 4 of 6, by ADDiCT
I've never used Steam-based game to host sessions before, so I'm not sure how the "invite" feature works. But if your friends are getting your internal IP adress in the invite they're not going to be able to join. Maybe Steam can be configured to use the external IP, but anyway typing the correct IP or hostname in the console will work 100% so why bother with the invites.
I would check the DoD readme or Google for the correct ports. Mods sometimes use ports different to their "parent" game.
That's not "static", that's a dynamically assigned IP. If you had static you'd get the same IP all the time. Static IP usually costs extra, and isn't useful for most home users. On the contrary, it can be a security risk.
Those config lines are used to "bind" the game to a specific network adapter (make it listen on a specific adapter). You don't need these lines unless you have multiple NICs in your machine.
Reply 5 of 6, by rfnagel
A-OK, thanks for the info 😀 I had inadvertently called it static, because even though it is dynamic, it's only changed twice since we first got the broadband back in February.
Rich ¥Weeds¥ Nagel
Reply 6 of 6, by rfnagel
I tried the "sv_lan 0" thing... same problem.
But, having my friends connect in the console via "connect <IP>:27015" (as well as adding the "<IP>:27015" to their "Favorites") worked like a champ 😀
Rich ¥Weeds¥ Nagel
