First post, by Sushi
I'm trying to run an old shooter 3d game on dosbox, Blood, to be exact. It works almost perfectly... though the only crucial problem, is that it has something about 2 or 3 frames per second, no matter how are set values of cycles or frameskip. Is there any smart way to boost it up? Cause now it's impossible to play with this. 🙁
Reply 1 of 4, by Gamecollector
core=dynamic.
cycles=max.
Try not to set the video resolution more then 640x480.
And the CPU must be as powerful as possible.
On my PC (p4 3GHz) Blood works good (~30fps) with this settings.
Reply 2 of 4, by Sushi
Thanks, it's fine now 😀
Reply 3 of 4, by leileilol
Updating dosbox to a recent version would help too.
Reply 4 of 4, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
