First post, by Paddan1000
- Member
My 486 motherboard only has one IDE connector. Since I want 2 harddrives and 1 CD-unit, I added an ISA IDE controller card called Promise EIDE Max. I used a PCI SCSI card for the CD before without any problems, but it used to much conventional memory, so I thought I would replace it with an IDE card instead.
However, with the Promise IDE card inserted, Emm386.exe won't initiate at start-up. I just get the error message:
"Emm386 not installed - unable to set page frame base adress".
Otherwise the computer boots as normal.
Here are two screenshots I took during the boot-up process.
http://img89.imageshack.us/img89/6453/imag0062o.jpg
http://img12.imageshack.us/img12/1207/imag0065r.jpg
The IDE card allows me to change settings by jumpers, like IRQ, primary or secondary IDE, BIOS address and BIOS enable or disable. I set it to secondary IDE, IRQ15, BIOS enable and BIOS address D000 (but I also tried D400).
