First post, by Barry_Purplelips
Other than my Voodoo1 running on the top of what I believe was a S3...no luck 😮
Reply 1 of 11, by batracio
All of them starting from Banshee.
Reply 2 of 11, by Barry_Purplelips
No way, even my FX5200 does it better.
Reply 3 of 11, by leileilol
Debian's fucked
Reply 4 of 11, by Barry_Purplelips
Voodoo3's VBE support is one of the worst in any voodoo card, it's slow and lacking a great deal of modes. FX5200's quite solid actually, pretty much like a 6200's except you don't get the annoying flashing garbage.
I'll see if I can get myself a Banshee.
Reply 5 of 11, by Davros
see if univbe wil give you more modes
Reply 6 of 11, by Barry_Purplelips
There's a model from each Voodoo line in my collection, though I always skipped over the entry-level market. I'm going to try the Banshee "just in case", but considering the record, I might be better off not getting anything. Univbe could work, but only to a degree, and the newer models are definitely helpless. Just wanted that "perfect" Voodoo that apparently never was.
Reply 7 of 11, by keropi
Care to give a riva128 (or 128zx) a try? Those have a VBE3.0 BIOS and are VERY fast and compatible vga's... I use them on my DOS machines, they never failed me!
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 8 of 11, by Barry_Purplelips
Yes I do because the riva128 isn't a voodoo 😁
Reply 9 of 11, by F2bnp
Voodoo 3 is basically a better Banshee, so if that won't work well for you, neither will a Banshee.
Reply 10 of 11, by keropi
well then, if you don't like the v3 then you are pretty much done with it, there is no better voodoo in terms of VBE support...
Reply 11 of 11, by Barry_Purplelips
Oh well, thanks for the suggestions anyways.
