improving DDRAW
First post, by neilcoal
some smart people made some ddraw utilities
with advanced features,
in an effort to make some old (software only) games look as if accelerated
mostly, the efforts went towards the 'wing commander' series
that's unfortunate, as i would also like to play with improved graphics
games like 'super ef2000', 'hind', 'fighters anthology' etc.
some tips/tools are welcome
also, any (free) programs to capture ddraw games?
(full screen & with sound)
thanks
Reply 1 of 13, by robertmo
i think 'super ef2000', 'hind' support 3dfx so no need for enchanced ddraw at least for these games
Reply 2 of 13, by dosmax
Super EF2000 doesn't support 3dfx.
A Voodoo patch, named GFX+, is only available for the DOS version of EF2000. Or, to be precise, EF2000 + TACTCOM add-on, aka. EF2000 v2.0 in the U.S.
You have to use a DosBox build with kekkos Voodoo board emulation to use it (i.e. Ykhwong). Glide wrappers won't work because Ef2000 GFX+ is one of the few games that were statically linked against Glide.
Reply 3 of 13, by Davros
fighters anthology has no hardware acceleration however ati's mlaa may work with it
Reply 4 of 13, by Jorpho
neilcoal wrote:
some smart people made some ddraw utilities with advanced features, in an effort to make some old (software only) games look as […]
If you're referring to "ddhack", we already have a thread about that:
ddhack
And the Wing Commander games in question weren't software-only; ddhack is basically just a wrapper for the DirectDraw DLLs.
http://sol.gfxile.net/ddhack/
If you're referring to something else entirely, then never mind. 😉
Reply 6 of 13, by neilcoal
thanks, i was only asking about a solution to make ANY directdraw game look better (tricking either the game or the videocard to start using direct3d or opengl features)
and frankly, i'm still not clear on the subject
but thank you nevertheless
cheers
Reply 7 of 13, by Davros
ps: hind has a glide patch
Reply 8 of 13, by Jorpho
Well, what you were asking about in your first post was about "software only" games, not "any directdraw game". There's a big difference there.
By the way, I've had pretty good results capturing games using BB Flashback Express. (It does not, however, support Win9x, if that's what you're looking for.)
Reply 9 of 13, by aqrit
Direct3D, DirectDraw, and OpenGL have all been ported run off each other...
gldirect
dxglwrap
wined3d
and of course ddraw is backed by GDI
Drawing one image on top of another is always going to look the same no matter what API you use.
Visual improvements really need to be done by hand for each game.
There are some hacks to run directdraw games in a window, etc.
DxWnd
Capturing DirectDraw shouldn't be to hard to do.
(The only issue to workaround is the locking of the primary surface)
kkapture won't record live gameplay
Reply 10 of 13, by Sol_HSA
cheers
Well.. "better" is in the eye of the beholder. Any modification to the original art is going to lose some information (by generating new data).
The "halfnhalf" filter (scale up with point sampling, then continue with bilinear) works pretty well in my opinion since it makes games look more or less like they did on worse quality monitors back then =)
As for just bilinear, or applying morphological AA or some such, those techniques may make the game look better, but at the same time they make some assumptions on the source data that was definitely not there when people still used deluxe paint 2 as the primary art authoring tool..
And as to the "any ddraw game", apparently doing a 100% functional ddraw re-implementation is nearly impossible. Thus, all approaches (apart from wine) aim some specific games.
http://iki.fi/sol - my schtuphh
Reply 11 of 13, by Jorpho
It is? How so?
Reply 12 of 13, by Sol_HSA
Jorpho wrote:
It is? How so?
I don't have any specifics, but this is from discussions with various ddraw wrapper dll devs.
Even microsoft has tons of ddraw-related application-specific hacks, or so I've been lead to believe.
Anyway, feel free to try. The source to ddhack is available. =)
