ddhack
First post, by Sol_HSA
http://sol.gfxile.net/ddhack/
So, just a heads up - I'm working on a "directdraw hack" to make some old windows games (more) playable on modern windows.
I'm concentrating on getting the windows versions of wing commander 1, 2, 3 and 4. Thread on wcnews.com forums here: http://www.crius.net/zone/showthread.php?t=26244.
Basically it's a reimplementation of ddraw.dll, which also hijacks the application's window function, and uses a desktop-sized window, outputting the game's input full screen with OpenGL, with optional filtering applied.
Once I'm done with it I'll release the sources so other people may use it as basis on getting other games to work.
It is *not*, by any means, a complete reimplementation, and I'm only hacking the bits that are required to get wc1-4 working; and many of those things are definitely hacks, kludges and generally bad things. So if other software works out of the box, it'll be a miracle.
http://iki.fi/sol - my schtuphh
Reply 1 of 33, by keropi
very nice work!!! although I don't play wc games, it is always good to see hacks like that appear!
Reply 2 of 33, by Harekiet
Rank DOSBox Author
DOSBox Author
Nice nice, always thought about doing something like this, seemed such a nice simple solution to running old stuff 😀
Reply 3 of 33, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Would be great if this covered the Windows versions of XCom UFO and TFTD... there is a fix for their ddraw bug, but the filtering would be nice to have.
Reply 4 of 33, by Sol_HSA
I don't have access to said games, but once I get the sources out, someone else may want to try it out.
Reply 5 of 33, by Miki Maus
Here is the essay from that guy who wrote the patch for XCOM:
http://f0dder.reteam.org/essay02.htm
Can this be of help? Can it be incorporated in your ddraw.dll as a generic solution for that problem? Because at least one other game comes to my mind that exhibits same symptoms as unpatched XCOM games on Windows: 7th Legion.
Reply 6 of 33, by Sol_HSA
What he did was a way more low-level hack than mine, but if this truly was the problem:
ignoring the fact that width!=pitch
..then yes, my dll does fix that. (as witdh == pitch in my software-driven virtual world)
Reply 7 of 33, by aqrit
Could OpenGL convert all frames from 16-bit to 32-bit color right before displaying?
So a game could run in windowed mode without setting the desktop to 16-bit color.
Reply 8 of 33, by Sol_HSA
ddhack actually runs in a window =) - the window just happens to cover the whole screen. Internally, I already convert everything to 32bit.
Reply 9 of 33, by leileilol
Hmm, all I get with using it is "CRT not initialized" what does that mean!
Reply 10 of 33, by Sol_HSA
Curious, I thought I got that fixed. I wonder if you used the last version?
Oh well.
In any case: now officially released:
http://iki.fi/sol/ddhack/
All source code, background story, pretty pictures and stuff.
Supported games: Wing Commander 1-3 for Windows from the "Kilrathi Saga" box, and Wing Commander 4 CD version.
Reply 11 of 33, by leileilol
Congrats on slashdot, hopefully someone extends it beyond WC (I don't have Windows WCs, only the DOS ones 😁)
Reply 12 of 33, by RoyBatty
ohhh, Wonder if this will fix Star Trek Armada, that would be awesome. Gonna check!
Reply 13 of 33, by Sol_HSA
I keep getting mails from random people regarding random issues with random games, but I don't have the time to support ddhack.
If someone wants to pick it up and be the "official" ddhack developer, ye shall have me blessing.
Reply 15 of 33, by Qbix
Rank DOSBox Author
DOSBox Author
then we would end up with lots of spam posts without a link in them and thus aren't able to spot them ?
And there are no member promotion rules on this system, so would have to promote people to normal users manually.
Water flows down the stream
Reply 16 of 33, by collector
Current phpBB automatically places new members in a "Newly Registered" group that has limited rights that can be set separately from those of the regular members. They are automatically moved to the regular members group after x number of posts. It is all configurable from the ACP.
Reply 17 of 33, by Qbix
Rank DOSBox Author
DOSBox Author
upgrading is not something that is planned soon.
Reply 18 of 33, by DosFreak
I compiled the latest SVN as of 4-28-2011 from the sourceforge page: https://code.google.com/p/ddhack/source/checkout
Using the 1.0 release I was able to get the Collector's Editions of UFO Defense and Terror From the Deep as well as Destruction Derby 2 working on Windows 7 64bit. These games would only work well on Windows OS's before Windows 2000. Starting with Windows 2000 all the way up to Windows 2008R2 the games would not work (at least for me) and would only work if run on Vmware using Windows 9x as a guest OS.
X-COM games still have a speed issue so use a speed limiter
Destruction Derby 2 freezes on exit.
Plan to test ddhack with more games this weekend
Make your games work offline
Reply 19 of 33, by mudlord
Thanks for the tests.
We need a compatibility list anyway.
Plus there is some Starcraft engine based game bugs left to fix...like the mouse capturing.
The speed limit idea sounds nice. Could do that. I've been chatting with Sol_HSA about the possibility of per game hacks to allow for said stuff like patchfixes for crashes, etc...Not to mention, it will help stuff like GTA1 compatibility and AOE compatibility.
