First post, by yellow2011
The controls (Keyboard, Joystick, Gamepad) do not repond at all in Dos version of MK2. I've already checked the manual but, still don't know what to do! Can anyone help? Please be specific as possible!
Reply 1 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
I advice you to do the same.
Be as specific as possible.......
on how do you run the game. Information about your system etc etc etc
Water flows down the stream
Reply 2 of 11, by yellow2011
I have a problem with MK3 dos version. First, after installing it, the controls don't seem to work well. It always move in one direction. Second, there is no background music. Not one single stage has music. Can anyone help?
Reply 3 of 11, by yellow2011
I install it on dosbox 0.74 from a dos cd-rom version but, the controls don't work at all. They do not respond. Even the keyboard doesn't respond. So I can't setup the DIP switches or choose characters to play with. It does however have sound and it shows story mode. Please help me! I have met all the system requirements. I have a powerful Pc. So it's not the Computer! I have a 4GB memory, 2.1 GHZ cpu, 2 640 GB harddrives, 2 lightscribe dvd burners and a AMD 8400 Phenom triple core processor. It's a 32 bit system. So it's not the computer. Can you help?
Reply 4 of 11, by eL_PuSHeR
[Duplicated posts merged and moved]
Well, Are you refering to MK2 or MK3?
Reply 5 of 11, by bloodbat
The music in the CD versions comes from the CD, so you need to have the CD mounted while you play...as for the controls...no idea.
Reply 6 of 11, by yellow2011
MK2 has no control respond at all and MK3's controls moves in one direction. I'll go through the manual again to figure out how to solve the problem with MK2. As for MK3, I'll try to mount the cd while playing the game like you said. Thanks for your'll help!
Reply 7 of 11, by leileilol
Try disabling joystick
Debian's fucked
Reply 8 of 11, by Gamecollector
Unfortunately, the DOS MK3 can't store the edited keyboard controls properly. So - delete mk3.cfg and setup the controls EVERY TIME.
Reply 9 of 11, by yellow2011
Ok! Thank you! I'll let you know how it goes.
Reply 10 of 11, by Gamecollector
1) File name is mk3keys.dat, not mk3.cfg.
2) DOS version included with MK3 Win95 don't have this glitch.
Reply 11 of 11, by yellow2011
Ok! Thank you! I will let you know if it works.
