Screenshots of the current CVS - round 2 (ADULT MATERIAL)
First post, by ChaosFish
I hope you won't mind this thread. After all, it's FUN to see more screenshots from the current CVS.
So please don't close this thraed. 😀
Here you may post all screenshots DOSBox' CVS running games that the latest stable realese can't run. Have fun!
Reply 12 of 72, by ChaosFish
Sweet mother of God! Rayman is running on the CVS!!!
use: mount D (cd drive letter here):\ -t cdrom -label RAYMAN -ioctl
If you choose a soundcard the game crashes, so you'll have to make do with only CD music.
    82.23 KiB
Reply 14 of 72, by Srecko
Pinball Illusions works with CVS !!
Both GUS, SB and PC speaker sound are working, but with a lag (emulation probably isn't fast enough for that).
Only problem in fact are higher resolutions:
If i select 360x350, game runs 336x350 mode(??), but it has scalew=2 and scaleh=1, while they should be both 2. And fps is too high (70), resulting in a too fast game. Obviously, some weird vga programming goes on here 😀 Btw, this behavior is exactly the same on my old Matrox Millenium I.
VESA 640x480 and 800x600 don't work as well.
I'll note that Pinball fantasies have almost the same problem with 320x350 mode except that game still runs at normal speed.
EDIT: This is from uploadit org. Damn, I now don't have any option about attachments
Reply 17 of 72, by Snover
Nono, no, I'll get it working yet, Just...be patient?? (Files ARE being uploaded, they just aren't being linked to posts.)
    8.54 KiB
    INUYASHA
Yes, it’s my fault.
