First post, by Robin4
Hi there..
Iam still being busy with my old XT computer..
Iam looking for an scsi harddisk for it because i have already an scsi controller over here.. And its a lot cheaper that building an XTIDE card.. Because its harder to get those parts to weld them on an pcb.. So i need to order those parts on ebay.. And shipping to the netherlands from USA isnt that cheap..
I have to questions.. Some drives they call them Half highed drives (HH)
Is this the same hight as an normal 5.25 inch device??
And second question. I never havent worked with scsi before.
1. I know i need an boot rom to boot from harddisk.
2. I need an 50-pin cable (thats support Scsi 1 en 2)
3. The controller card needs to get terminated.. ID select always 0..
Question: Do the harddisk get terminated if put it on te end of the cable?
Question: Do i need an seperated terminator if i put the harddisk closer to the ISA controller card (and put the terminator on the end of the cable)
(does the harddisk then work if its not defect)
Reply 2 of 6, by megatron-uk
Robin4 wrote:
Hi there.. […]
Hi there..
You don't need to build the xt-ide card. You only need a network card or other 8/16 bit is card with an eprom/eeprom socket. There are plenty of 8 bit ne2000 type cards on eBay that you can use. I'm using a 16bit 3com in my setup.
https://www.target-earth.net
Reply 3 of 6, by Amigaz
The last device in the SCSI chain, in this case you hdd need to be terminated, some older SCSI hdd's had onboard resistor packs..if not you need to get an active SCSI terminator like this one:
Just put in on the last connector on the SCSI cable and the hdd on the middle connector on your SCSI cable
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 4 of 6, by Robin4
Ok so the device that is in between the controller and the last drive dont have be terminated?
So the intention is to make an closed chain??
So if the hard drive is already been terminated the best spot to place it is on the last connector of the cable? If not then i need to pace that recommend terminator on the last end and then put the harddisk between the controller card en terminator..
If this is right then iam getting it..
Reply 5 of 6, by Amigaz
Robin4 wrote:
Ok so the device that is in between the controller and the last drive dont have be terminated? So the intention is to make an cl […]
Yep, correct 😀
