First post, by resin
- Newbie
There are some issues with The Lost Files of Sherlock Holmes: Case of the Serrated Scalpel. Basically you encounter freezes and audio pops during gameplay. After some research, I found that running in .73 you can at least avoid the freezes, but in .74 you're completely out of luck unless you can modify the source and recompile, which I for one wouldn't know how to do..
From what I've gathered, the reason it freezes in .74 is in some way due to an error exit for DMA wrapping. So I'm wondering, will this issue be fixed in the next version of DOSBox? Furthermore, for the time being, could someone explain how exactly I'd need to change the .74 source in order to avoid these freeezes and audio pops? And if I make these changes, can it cause problems with other games using the same modified source?
