Reply 40 of 47, by egons
this one..
original .amd
Reply 41 of 47, by Malvineous
The converter only converts .dro files, not .amd. You will need to play the file through DOSBox (version 0.72) and capture it as a .dro file first.
Reply 42 of 47, by egons
yeah, sure.
try to play and capture song from Amusic and convert grabbed .dro-file
converter says like unsupported 2.0*facepalm*
Reply 43 of 47, by Qbix
Rank DOSBox Author
DOSBox Author
did you use the right dosbox version? As the dro format has been changed.
Water flows down the stream
Reply 44 of 47, by egons
nope, i have 0.74 with debugger version(one doesn't grab tunes)
does anyone grab song and convert to MIDI for me, please?
Reply 45 of 47, by Malvineous
If you can post the DRO v2 file I can convert it to DRO v1 for you, which DRO2MIDI will accept.
Reply 46 of 47, by egons
i've found 0.74 portable, with no result.
will attach new capture.
thanks!
256bytes.net - demos all-in-one
Reply 47 of 47, by egons
oh, my friend did the best - he's made tune from the attached file.
thanks!
btw, some .dro-editors/tools like a Hewston *still* have a problem..
