Doom III source code released under the GNU GPL v3
Schedules and announcements about program releases.
Postby leileilol » 2011-11-23 @ 00:07
no article so i'm just going to link to the repository tree where you can snag it.
https://github.com/TTimo/doom3.gpl
Voodoo2s aren't 100mhz stock
Geforce256 isn't released as a beta on New Years '99 under the Quadro brand
386DX vs SX isn't about a missing FPU
DOS gaming isn't a bilinear 320x200 16:10
DOS PCs aren't better than the Macintosh
Old PCs aren't 'aesthetic'
User avatar
leileilol
Re: Doom III source code released under the GNU GPL v3
Postby The Gecko » 2011-11-23 @ 08:58
And an article to go with it.
Interesting bit about them having to do some emergency re-coding to avoid possible patent issues.
If all else fails, use fire.
User avatar
The Gecko
Postby sliderider » 2011-11-23 @ 12:33
Says here
http://www.shacknews.com/article/71134/ ... rites-code
that the new algorithm puts a drag on performance when run on 2004 hardware because it has to do twice as much work to achieve the same results as the previous code. If you're trying to run this version on older hardware, you may not like the performance compared to the original. You're probably going to be better off paying for it if you need to run it on old hardware.
User avatar
sliderider
Postby The Gecko » 2011-11-23 @ 16:09
I derive a sort of twisted amusement out of the fact that the algorithm is largely known as "Carmack's Reverse", but Carmack himself can't actually publish it because of software patents.
And of course, (assuming it was patented in 2004), it'll be 2024 before anyone can start using it, at which point it will almost certainly be completely irrelevant, because 20 years is eons in computer-land (the widescale adoption of internet use by the public is significantly younger than 20 years)
User avatar
The Gecko
Postby F2bnp » 2011-11-23 @ 19:48
It doesn't exactly say that is does indeed drag on performance. It would have back then, but there may be alternatives nowdays and knowing Carmack, he would choose to implement the best alternative.
User avatar
F2bnp
Postby leileilol » 2011-11-23 @ 22:34
The Gecko wrote:And of course, (assuming it was patented in 2004)
It was patented in 1998 I believe.
Didn't Creative have a special (but broken) 3D Blaster TNT Unreal driver with "Carmack's Reverse" shadows?
User avatar
leileilol
Return to Release Announcements
Who is online
