First post, by exofreeze
- Member
Hello all.
I have recently installed SimIsle by creating an ISO, imgmounting it, and running the disc based install (dosbox 0.74).
The game seems to install fine, and using the standard launch batch file (go.bat), the game will launch - however the opening screen is blank with music playing behind it. If I hit esc a few times to skip the intro, the main menu pops up and the game seems to look fine. basically any type of video whacks out the game again though.
There is a second launch file called "govesa.bat", which simply launches univbe prior to calling the original "go.bat" file.
Attempting top run this causes the game to launch, think for a bit, and then return the following:
TRACE :
Errlong <nul> opened. Mon Dec 19 08:54:55 2011
TRACE :
Currently I am have the conf file set to 8mb of ram, xms/ems/umb true, cycles max (have tried limiting this in case that was the issue), core is auto.
Thanks for reading, hopefully someone can help =)
