First post, by exofreeze
- Member
Trying to play the game Tamper:
http://www.mobygames.com/game/dos/tamper
A search showed another fellow had this issue, although it never seemed to be resolved.
Essentially, clicking 'New Game" on the menu leads to an insufficient disk space error.
I have tried setting the freesize of drive C to 5, 10, and 100 megs respectively.
Current conf:
[sdl]fullscreen=falsefulldouble=falsefullresolution=originalwindowresolution=originaloutput=surfaceautolock=truesensitivity=100waitonerror=truepriority=higher,normalmapperfile=mapper-0.74.mapusescancodes=true[dosbox]language=machine=svga_s3captures=capturememsize=4[render]frameskip=0aspect=falsescaler=normal2x[cpu]core=autocputype=autocycles=autocycleup=10cycledown=20[mixer]nosound=falserate=44100blocksize=1024prebuffer=20[midi]mpu401=intelligentmididevice=defaultmidiconfig=[sblaster]sbtype=sb16sbbase=220irq=7dma=1hdma=5sbmixer=trueoplmode=autooplemu=defaultoplrate=44100[gus]gus=falsegusrate=44100gusbase=240gusirq=5gusdma=3ultradir=f:\ULTRASND[speaker]pcspeaker=truepcrate=44100tandy=autotandyrate=44100disney=true[joystick]
joysticktype=autotimed=trueautofire=falseswap34=falsebuttonwrap=false[serial]serial1=dummyserial2=dummyserial3=disabledserial4=disabled[dos]xms=falseems=trueumb=falsekeyboardlayout=auto[ipx]ipx=false[autoexec]cd ..cd ..mount c .\games\Tamper88 -freesize 100mount a .\games\Tamper88\floppy\ -t floppyc:cls#cd tampertamperexit
I tried mounting an empty folder as an A; floppy, in the event it expected to save to floppy. I have played with the ems, umb, and xms switches. it doesn't seem to care unless you turn ems off at which point it will refuse to launch.
I have tried simple, normal, and auto CPU types.
I have tried 4, 8, and 16 for the memsize.
I have tried launching the game from a C:, and from c:\tamper in the event the game requires being run from a specific directory.
Any other thoughts? Thank you!
