First post, by lolo799
Hello, I found a lot of sound cards related threads on this forum, but not much about the Pcmcia sound cards except for a few post about the Roland SCP-55.
I own more than 10 different models, most of them work in pure DOS and only one of them work in anything newer than Windows 9x:
-Roland SCP-55
SoundCanvas and MPU-401 GM device in DOS + digital audio in Win3.x/Win9x
Drivers for DOS/Win3.x/Win9x: http://www.rolandus.com/support/eula/SCP55.EXE
For Linux and for the HP100/200LX: http://zo-kun.to/~risyu/scp55/
Manual: http://media.rolandus.com/manuals/SCP-55_OM.pdf
-EXP Soundnote,
ESS ES688P
Adlib/SB FM and MPU-401 in DOS + digital audio in Win3.x/Win9x
The breakout box has an integrated mono speaker.
Drivers: http://www.expnet.com/know.nsf/a87c96fe8c9775 … 66?OpenDocument
or http://www.expnet.com/know.nsf/a87c96fe8c9775 … fc?OpenDocument
Manual: http://www.expnet.com/know.nsf/f36fb1d8958b43 … /$FILE/S-16.pdf
-RATOC REX-5570
ESS ES1688P
Adlib FM and MPU-401 port in DOS + digital audio in Win3.x/Win9x
Drivers: http://www.ratocsystems.com/services/driver/sound/5570.html
Manuals: http://www.ratocaudiolab.com/img/dl/manual_pdf/5571.pdf
or http://www.ratocaudiolab.com/img/dl/manual_pdf/5571w.pdf
Product website: http://www.ratocsystems.com/products/subpage/5571.html
-Eiger Labs/Fujitsu 16-bit Stereo Sound
ESS ES1688
Adlib, SB and SBPro FM, MPU-401 in DOS + digital audio in Win3.x/Win9x + SB/Pro DMA emulation in Win9x
It comes with a simple dongle (phone out/line out/line in) but it can use the Ratoc breakout box with MIDI IN/THRU/OUT
Product website: http://web.archive.org/web/19961103210304/htt … abs.com/mm.html
Drivers: http://lorezan.free.fr/pcmcia/fujitsu-eigerme … bit%20sound.zip
or https://web.archive.org/web/20030806102236/ht … ort/support.htm
-IBM 3D Sound Card
IBM MWAVE
SB FM and digital audio in DOS/Win3.x and OS/2 Warp
Drivers for DOS/Win3.x and OS/2:
http://support.lenovo.com/en_US/downloads/det … ?DocID=DS001550
-NewMedia Wavjammer
Adlib OPL2/OPL3 FM + digital audio support in selected games in DOS/Win3.x (using Miles Sound System), WSS-SB emulation in Win9x
Drivers: ftp://ftp.axiz.com/PCCards/newmedia/sound%20g … orts/wavjammer/
-Newmedia Sound/SCSI2
Identical to the Wavjammer with SCSI 2 capability
Drivers: ftp://ftp.axiz.com/PCCards/newmedia/sound%20g … oast%20&%20jam/
-Panasonic Sound Card CF-VEW211
Yamaha OPL3
OPL2/OPL3 FM in DOS + digital audio in Win3.x/Win9x
Drivers: http://lorezan.free.fr/pcmcia/panasonic/cfvew211.rar
DOS enabler: http://www.ss.iij4u.or.jp/~riki/panas13.lzh
-Panasonic Sound Card Pro CF-VEW212
Yamaha OPL4
OPL4 + digital audio in Win9x
Drivers: http://lorezan.free.fr/pcmcia/panasonic/cfvew212.rar
Both Panasonic cards have a special option I haven't seen anywhere else, it can output the FM( DOS) or FM+DA (Win9x) generated by the card using the PC speaker, yes you read that correctly!
The card doesn't even need the breakout box plugged in for this, so you can enjoy playing Doom using Adlib music and PC Speaker digital audio outputed at the same time on the poor PC Speaker, even on systems that don't have an integrated sound card and only a very basic system speaker, and it sounds quite good.
Also they don't suffer from the infamous OPL3 slowdown in the Descent sound setup.
-TDK Music card 8000
EMU8000, 2MB wavetable sample ROM, 512KB RAM
General MIDI in DOS/Win3.x/Win95
Its breakout box has a S/PDIF output, MIDI IN/OUT and analog IN/OUT.
Drivers for Win95: http://web.archive.org/web/20060512034948/htt … 01/bda01020.htm
Product website: http://web.archive.org/web/19991009105447/htt … 01/bda61000.htm
FAQ: http://web.archive.org/web/19980625005458/htt … 01/cab14000.htm
-TDK Digital Music Card 9000
EMU8000, 4MB wavetable sample ROM, 2MB RAM
General Midi and MPU-401 in Win9x
No DOS support at all, not even in Win9x DOS mode.
Drivers & utilities: http://web.archive.org/web/20051121005831/htt … 01/bda01010.htm
Product website: http://web.archive.org/web/19990922002740/htt … 01/bda80000.htm
Have a look at the extended DMC-9000 control panel:
I'll make some recordings of the better cards, including the Panasonic Inside Speaker option, the OPL4 FM and the TDK playing midi music.
Here's a list of the 16-bit cards I don't own:
-Media Vision Pro Audio PCMCIA
-Turtle Beach Audio Advantage PCMCIA
-VisionTek Business Audio Card (same the Turtle Beach AA)
-Apex Data Audio Express
-I/O Magic Tempo
-EMU 8710 (same as the TDK MC8000)
-EMU 8710SP (same as the TDK DMC-9000)
-Argosy PCMCIA (same as  the EXP Soundnote)
-MediaMagic PCMCIA sound card
-DSP Solutions PORT.ABLE Sound PCMCIA
-New Media GameJammer
-A-B Soft AB Sound (same as the Fujitsu/Eiger Media cards)
-Yamaha PCC10XG
-Digigram PCXPocket & VXPocket series (the PCXPocket series have DOS drivers)
-Ratoc REX-5571 (REX-5570 + joystick port)
-Ratoc REX-5572 (REX-5571 + SCSI, no MIDI IN/THRU/OUT)
-Panasonic CF-JSC101 (Sound/SCSI)
-Panasonic KXL-C101 (Sound/SCSI)
-Panasonic KXL-D20/DN20 (Sound/CDrom)
-Logitec LPM-SU100 (same as the Panasonic CF-VEW212)
-Logitec LPM-SCSU
The next two cards are joystick controllers that can be used as a MIDI interface with the usual DB15 to 5-pin cables:
-I/O DATA PCJOY2
-New Media Mobile Gamer
There are some parallel port devices wich could be interesting, but beyond the scope of this thread:
-DSP Solutions PORT.ABLE Sound Plus
-Logitech AudioMan
-Media Vision Audioport
