First post, by maddmaxstar
- Member
As a spinoff of my K6-2+ 500 thread, on the suggestion of Tetrium, creating here a seperate thread for everyone from far and wide to post their Retro system's SuperPi results.
There is a copy (Freeware) of SuperPi 1.1 (Modded for decimals) attached to this post that will run on Win9x operating systems all the way to XP. Works on 7 too, but this versions not for multicore CPUs. As SuperPi relies on the x86 instruction set, it should theoretically run on 486 machines as well, but haven't tried this yet.
Test Guidelines:
All tests run at 1M, a setting appropriate for Pentium/II/III class CPUs, as anything bigger would take too long, yet is big enough to show comparitive performance. (If you use anything other than 1M, please document it.)
Also document any additional system specs, Motherboard Chipset, L2 Cache (if on motherboard), RAM quantity and type, OS. Also document FSB and multiplyer settings if running out of spec (ie: a K6 300, running at 3x 100MHz FSB instead of 4.5x 66MHz)
So far I've run a few tests, as follows:
System: FIC VA-503+ VIA MVP3+1MB L2/256mb PC100/Win98se
AMD K6 300MHz (3x100) = 10m 9.360s
AMD K6-2 300MHz = 10m 29.702s
AMD K6-2 350MHz = 9m 47.740s
AMD K6-2 400MHz = 9m 07.807s
AMD K6-2 450MHz = 8m 54.413s
AMD K6-2 500MHz = 8m 26.852s
AMD K6-2+ 500MHz = 6m 20.973s
System: FIC SD11 AMD751+VIA686A/512mb PC100/WinXP
AMD Athlon 550MHz = 4m 13.074s
AMD Athlon 700MHz = 3m 38.915s
System: AOpen M3XW Pro-V i810+Voodoo3 2000PCI/512mb PC133/WinXP
Intel Celeron 466MHz (Mendocino 7x66) = 5m 03.346s
Intel Celeron 800MHz (Coppermine 8x100) = 3m 29.461s
Intel Pentium III 650MHz (Coppermine 6.5x100) = 3m 25.365s
System: IBM Thinkpad 380XD/96mb EDO/Win98se
Mobile Pentium MMX 233MHz (Tillamook on MMC-1) = 12m 24.011s
System: IBM Thinkpad A20m/128mb PC100/Win98se
Mobile Celeron 500MHz (Coppermine, Skt 495) = 6m 00.120s
System: MSI Skt939 ATi Xpress200+X800GTO/1GB DDR400(1x512+2x256, single channel)/Win7x64
AMD Athlon 64 3700+ (2.2GHz 1MB L2, San Diego) = 45.312s
System: HP G62-365CA(880G)/4GB DDR3-1333/Win7x64
Phenom II X3 E840 (1.9GHz, Caspian core, 3x512mb L2 Cache, No L3) = 41.169s
System: MSI MediaLive Diva (780G+128mb Sideport)/4GB DDR2-667 Dual Chan/Win7x64
AMD Athlon 64 X2 4400+ (2.3GHz Brisbane 65nm 2x512k L2) = 39.204s
System: Asus M3A78-EM(780G)/4GB DDR2-800 Dual Chal/WinXP-MCE05
Athlon X2 4850e (2.5GHz Brisbane, 2x512k L2) - 36.219s
System: Asus M5A88-E(880G)/16GB DDR3-1600/Win7x64
Phenom II X6 1090T (3.2GHz+Turbo, Thuban Core, 6x512k L2, 6MB L3) = 21.434s
And these results originally posted by Tetrium in my K62+500 thread:
System: Pentium III 933Mhz/VC820/256MB RDRAM PC-800/WinME
3m 9.189s
System: Pentium III 1400Mhz/256MB SDRAM PC133(cl3)/i815 chipset/WinME
126.150 seconds (2m 6.150s)
= Phenom II X6 1090T(HD4850) =
= K7-550(V3-3000) =
= K6-2+ 500(V3-2000) =
= Pentium 75 Gold(Voodoo1) =
= Am486DX4-120(3DXpression+) =
= TI486DLC-40(T8900D) =
= i386sx-16+i387(T8900D) =
