First post, by keropi
- l33t++
Hiya! 😊
(first the compulsory introduction/history info with some pics)
Last week I was given for free an older pc that was running XP inside a humongous and heavy older Thermaltake tower... at first I was kinda meh about it, it turned out to be a p4 @2.4ghz, with an agp-pro mobo, 2x256MB DDR1/400 sticks and a GF4200ti/64MB ... so I left it sitting on the self...
Yesterday I decided to open it, remove the parts and maybe donate that heavy tower to someone locally... When I opened it I saw this (without the dedicated soundcard)
and some more info from cpu-z:
not bad 😊 , the mobo is a Gigabyte GA-8IK100 rev2.0 so I decided to install winME on it just for laughs and see if Severance: Blade of Vegenance was running smoothly on it... and ofcourse it did 😁
Now the test setup/testing process was VERY VERY breeze, I even used a sata HHD to install winME (setup BIOS to configure sata ports as IDE0) and all drivers installed fine without BSODs or surprises. It works fine after usage , gaming and benchmarking. (Only 2 days of testing though but still no probs yet). It even shutdowns/powers off normally without hdd's powering on/off or other shenanigans 😁
Did some 3Dmark2001se benchmarks following the recent trend:
GF4/4200ti/64MB/AGP4x: 9902
GF5/5700/256MB/AGP8x: 11033
As you can see the difference is small and I favor the 4200ti for now because the 5700 is a heavy aluminum brick with passive cooling that provides small performance increase.
Now I am seriously thinking to keep this machine (inside a normal tower and not a 15kg overclocking one with knobs for fans) for win9x D3D games that need more power than my tualatin+v5500 setup can provide. They should not necessarily be super-gfrx titles, but the p4 horsepower can make them run at 60fps or way more smoothly... (like severance for example)
And since my knowledge with older directx games and "modern" systems stops at the v5500 setup, I present you with the following questions:
a. is it worth to upgrade to anything faster than a GF4 gpu? I can get a GF6/7 agp from eBay but would there be a point? (if something needs a 6/7 then it is probably too modern for win9x and I can run in on my main pc which has a 560ti) Also keep in mind I am an nVidia fan ,if possible I would like to use an nv card here unless there is a good reason not too.
b. Following the above q, is there a top-level vga that beyond that some things break for DX7/8 games?
c. As you can see the current cpu is a HT one, I remember vaguely reading here that it causes probs to older titles, is this true? (there is an option in BIOS to disable HT, does it fixes any probs that might exist?)
Sorry for the long post, all advice/info would be greatly appreciated 😀 , thanks!
edit: here's a stock pic of the tower it came with, looks like this, full tower and with a fan on the top too... that drive door alone must weight 1+ kg alone!
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
