First post, by rcblanke
- Oldbie
Hi All,
recently I stumbled upon a second game where my joystick buttons were not responsive in DOSBox 0.74, while everything was Ok in another version (the game was GBA Championship Basketball: Two-on-Two). Anyway, it turns out it was not so much a problem with the DOSBox version, but with the associated mapper file. Instead of the default contents (in which both games work fine with a joystick)
...jbutton_0_0 "stick_0 button 0"jbutton_0_1 "stick_0 button 1"jaxis_0_1- "stick_0 axis 1 0"jaxis_0_1+ "stick_0 axis 1 1"jaxis_0_0- "stick_0 axis 0 0"jaxis_0_0+ "stick_0 axis 0 1"jbutton_0_2 "stick_0 button 2"jbutton_0_3 "stick_0 button 3"jbutton_1_0jbutton_1_1jaxis_0_2- "stick_0 axis 2 0"jaxis_0_2+ "stick_0 axis 2 1"jaxis_0_3- "stick_0 axis 3 0"jaxis_0_3+ "stick_0 axis 3 1"jaxis_1_0-jaxis_1_0+jaxis_1_1-jaxis_1_1+jbutton_0_4 "stick_0 button 4"jbutton_0_5 "stick_0 button 5"jhat_0_0_0 "stick_0 hat 0 1"jhat_0_0_3 "stick_0 hat 0 8"jhat_0_0_2 "stick_0 hat 0 4"jhat_0_0_1 "stick_0 hat 0 2"mod_1 "key 306" "key 305"mod_2 "key 308" "key 307"...
the mapper file was somehow, at a certain moment in time altered to
...jbutton_0_0jbutton_0_1jaxis_0_1-jaxis_0_1+jaxis_0_0-jaxis_0_0+jbutton_0_2jbutton_0_3jbutton_1_0jbutton_1_1jaxis_0_2-jaxis_0_2+jaxis_0_3-jaxis_0_3+jaxis_1_0-jaxis_1_0+jaxis_1_1-jaxis_1_1+jbutton_0_4jbutton_0_5jhat_0_0_0jhat_0_0_3jhat_0_0_2jhat_0_0_1mod_1 "key 305" "key 306"mod_2 "key 307" "key 308"...
My questions; what could be the cause? And what does the change mean/imply? I can't remember me fiddling with the joystick mapping myself, so I guess the changes were triggered by something different.
regards,
Ronald
edit: oh, I just hit a thousand!
